Off-Road Forums & Discussion Groups - View Single Post - Body lift and steering shaft
post #1 of (permalink) Old 03-23-2003, 08:54 PM Thread Starter
muddog
I finally put in a 3 inch body lift today. Wouldn't advise doing it again, but its done. How much should the steering shaft slide? When I put the blocks in I really jacked the drivers side up because of the way my jack was positioned. Then after I was all done, I slid the boot from the steering shaft seam, and it looked like it had already slid about 1/2 inch or so. Does this sound right? If it doesn't slide apart far enough, what can happen?
Also, I wasn't able to bolt my shifter boot back in the same place because the shifter wouldn't go back far enough(had to do some generous trimming). Is this common with this lift?
muddog is offline
