Off-Road Forums & Discussion Groups - View Single Post - Relay Questions (Jump in here Leve!)
post #7 of (permalink) Old 02-27-2003, 03:56 PM
Jim_Lou
Re: Relay Questions (Jump in here Leve!)
I'm one of those who likes to have relay's all over instead of in one place. That way I avoid running heavy wire into the cab. For example, I put headlight relays under the hood between the battery and the lights. That keeps the run of 10-gauge wire short, which means less voltage drop and consequently higher voltage to the lights.
The wire that runs the relay coil can be small - 20 or 22 gauge would be sufficient, but I don't use smaller that 18 because really small wires are fragile.
One more thing; a resistive load such as a light will draw more current as the voltage goes up, not less. In fact, just about everything on a Jeep will draw more current as the voltage goes up. A radio might be the only exception.
Automotive lights are probably rated at 14 Volts, but I don't know for sure. A DC ammeter isn't expensive, and will let you know what your accessories are really drawing.
Jim_Lou is offline
