ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > ATV Forums > Youth ATV Discussion Area
Youth ATV Discussion Area For discussion of all youth ATV's 125cc and smaller.
Old 11-16-2006, 11:45 PM
808viewer
Default HELP!! HELP!! 2002 SUZUKI LT50
I HAVE A LT50 THAT I DID SOME OF THE MODS THAT OTHERS ON THIS BOARD HAVE SUGGESTED.
1. REMOVE INTAKE RESTRICTOR
2. COULD NOT FIND EXHAUST ONE BUT I THINK THE PREVIOUS OWNER REMOVERED THAT ONE. I TOOK OFF THE PIPE AND THERE WAS NO "WASHER" THERE.
3.REMOVED THE FIRST SMALL JET AND LEFT THE LARGER LONG ONE IN PLACE.
4.MOVED THE NEEDLE CLIP TO THE 3RD POSITION FROM THE POINT SIDE UP (STOCK IS ON THE SECOND)
THE PROBLEM IS NOW IT WILL ONLY IDLE. WHEN I GIVE IT SOME THROTTLE IT DIES. I HAVE NO IDEA WHAT TO DO. COULD ANYONE GIVE CLEAR STEP BY STEP INSTRUCTIONS AS TO WHAT ELSE NEEDS TO BE DONE THAT I MISS. THANKS FOR ANY HELP
Old 01-28-2007, 05:52 PM
Stranger
kraig is an unknown quantity at this point
Default Re: HELP!! HELP!! 2002 SUZUKI LT50
The only mods I've done to my boys LT50 are : Drill four 3/4 holes in the air breather CAP... and removed the spark arrestor inside the muffler., two screws and pull the the end off and slid it out, tap the end cap back on. Made a heck of a difference. [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
