ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > ATVs, Quads and Four-Wheelers > Utility/4x4 ATVs
Utility/4x4 ATVs All discussions of Utility and 4x4 ATV's, quads, four-wheelers.
Old 02-23-2005, 01:06 AM
Garland
Default \'05 Kodiak 450 Auto \"Help\" mounting my winch?
Im installing a Warn 2500 winch myself and can't decide where to locate the "Contactor" (isolator) any sugestions??
Old 02-23-2005, 08:48 PM
Jimmy454JRC's Avatar
Journeyman
Jimmy454JRC is an unknown quantity at this point
Default Re: \'05 Kodiak 450 Auto
Is there a rear storage box?
If so mount it just above that and under the plastic for the body.
Anywhere it should remain protected from flying debis, reasonably free of mud and/or water.
Old 02-24-2005, 01:14 AM
Garland
There is a storage box under the seat next to the battery. I will place it inside the storage box unless someone has a better location? Thanks for the Help!
Old 02-25-2005, 11:19 PM
huntinok
Default Re: \'05 Kodiak 450 Auto \"Help\" mounting my winch?
I mounted mine on the inside of the right fender as high as it would go. I have had no problems and ride in high water every now and then. You will have to use the red and black battery cables to run from the contactor to the winch and the yellow and blue cables to run from the contactor to the battery. This way you can keep your storage box under the seat for, well, storage. Also you won't have to worry about your cables getting pinched between the seat and the storage box. [img]images/graemlins/smirk.gif[/img]
  #5
Old 02-26-2005, 12:35 PM
Garland
Thanks G.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
