I have a 93 Polaris 350 atv. When I start it it will bog out in fwd low and high and nuetral when giving it gas. Will not move unless I tap starter then will move momentarily. It will go in reverse. Sense it has something to do with throttle / auto clutch/ fuel problem? Will backfire profusely while doing this. Checked transmission and changed oil, changed spark plug. no luck. Any help much appreciated. Thanx.
<font color="blue"> </font color>
My husband had the same exact problem with his '98 explorer400. It ended up being the switch < by the gear [img]images/graemlins/confused.gif[/img]shift > AND the light/on/off switch. Replaced them both and it works like a charm.Hope this helps.....
Finally figured it out. Was the ETC switch that would over heat and short out causing engine to miss. Disconnected the black wire from ETC module and walla. it works but no limited speed in reverse. Thanx for all your help.
Off-Road Videos - Check out over ten years of extreme 4x4 action, product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it's all here. Rate them, share them and upload your own.
ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles.
Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy!
