ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > ATVs, Quads and Four-Wheelers > Utility/4x4 ATVs
Utility/4x4 ATVs All discussions of Utility and 4x4 ATV's, quads, four-wheelers.
Old 02-08-2003, 03:12 PM
Default 10\" wheels on Blaster axle-Which hubs?
I am in the middle of building "Quadzilla", a 93 Yamaha Timberwolf with a 79 Suzuki GS550 engine. The motor is installed and running, and I have converted the rear swingarm and axle setup over to one from a 2001 Blaster. The Blaster axle did not have wheel hubs when I got it. The Timberwolf came with 10" rims all around, and I would like to keep it that way. I was told that all Blasters had 8" rear wheels, but I have heard that there are different hubs (Banshee?)to fit 10" wheels to this axle. Does anyone know what I need to be looking for? Or will I be stuck with running 8's? And no, the T'wolf hubs won't fit the axle....
Thanks!
John
Old 02-09-2003, 11:54 AM
Warrior00
Default Re: 10\" wheels on Blaster axle-Which hubs?
well 1st u have to find a set of hubs that have the same bolt pattern as the twolf tires and that will fit a blaster axle. other wise get some 10' rims that have the same bolt pattern as the blaster hubs.. i would recommend getting a set of banshee hubs the bolt pattern because the raptor shee and warrior all have the same bolt pattern and the blater has a differnent one but some hondas have the blaster pattern
Old 02-11-2003, 07:16 AM
use the Blaster hubs. you can get used ones at 870-458-2939, Harber's Cycle Salvage. ask for Dennis. the bolt pattern is 4 on 100mm . ITP makes 10" rims with this bolt pattern.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
