ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 12-13-2000, 08:58 AM
Default transmission
I have a 96 taco 4cyl.What is the best fluid to use in the manual trans. Also are there any tricks to doing this. Thanks KB
Old 12-14-2000, 10:47 AM
Default Re: transmission
Boydog, if I'm not mistaken the owner manual recommends a 75-90wt gear oil (forgot if it's APS 4 or 5). I personally use Valvoline. Never had any problems. The trans has a drain bolt on the bottom and a fill bolt on the side (driver side). Easy to change. Hope this helps.
AAM
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
