OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 10-30-2007, 08:01 PM
Stranger
surfrat is on a distinguished road
Default 99 Tacoma Suspension Lift
Hi,
I have a 4cyl 99 Tacoma SR5 ext cab. Right now it has 31 in tires but i want to put a 2 in suspension lift on it so i can put 33's on it. I was wondering what would be the best lift to put on it that will be easy to put on and won't affect the brakes, steering geometry, etc. too much. Also so it will still be good for on-road and highway driving.
Old 10-31-2007, 09:40 AM
redtoy92's Avatar
Pooh-Bah
redtoy92 is on a distinguished road
Default
Quote:
Originally Posted by surfrat View Post
Hi,
well everyone could call different lifts best for what they want. But it sounds like a nice set of coilovers(kings, hoes, SAW's, etc) are what you are looking for in the front and a new leaf pack with about 1.5 inchs in the rear. If you do not want to spend that much on the rear then you can just get a block or add leaf but it will not be as smooth on road and may effect braking a little.
__________________
03 ext.cab v-6
charger+ URD kit+4in DP
6inch fabtech+ 1in RB
35'BFG mud+15x10 crome optimas 4.88's
stubbs sliders
rhino lining
Old 11-24-2007, 10:31 PM
Stranger
Default
Quote:
What I'm looking to do now is something like Donahoe coilovers for the front suspension which will offer 2-3 in of lift. For the rear suspension a Deaver 7 leaf spring pack and Bilstein 5100 rear shocks which combined will give 2-3 in of lift. This is supposed to be able to clear 33 in tires. My question is if I install a lift like this, will I also have to put in new gears to make up for loss of torque? Or will I be able to get away without them?
Thanks
Old 11-25-2007, 09:56 AM
redtoy92's Avatar
Pooh-Bah
Default
well that is the game you play with lifts and tires. All i see is that you have the 4 banger which coule be a 2.4 or 2.7. If it is the 2.7 you might be ok but I would think you will lose 5th gear in the freeway when going up hills. The only way to know is to do it and see if you can live with the difference. If not then yes you will want to regear. If you do it and it is not that bad then you will be able to live with it.
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
  #5
Old 12-18-2007, 03:45 PM
Stranger
Default
Thanks for all the advice. Ive got one more question. This truck will still be a DD including a small stretch of highway. If I put the lift on will it put too much strain on the CV's to drive daily.
  #6
Old 12-23-2007, 10:26 AM
redtoy92's Avatar
Pooh-Bah
Default
well if you stay with 2inch and 33's or I would go with 32's it will be fine. More stress yes, but not more then it can live with.
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
  #7
Old 01-01-2008, 05:46 AM
Stranger
noelliam is on a distinguished road
Default
I am trying to solve a problem here. I have a 2000 Tacoma with a 3 inch spacer lift and a 3 inch body lift. Within 2 months of doing the lifting, I have had the rear brakes go out completely, and the entire driveline go out. Now, the guys at the dealership said that when I put the suspension lift on, it threw the driveline angles off, therefore destroying the u joints. I have done lifts before, and I tought that the whole idea of the lift block being tapered was to correct the driveline angle. The fact of the matter is I deliver food 12 hours a day in this thing, and it has 180,000 miles on it. My question is did the lift tear it up or the excessive wear and tear of delivering pizzas for the past 8 years? I realize a lifted truck is not the best vehicle to deliver in, but I am not worried about the shitty gas mileage. 200 a night in tips covers that, but what I am worried about is what problems I will encounter if I were to go with a 33 inch bogger, or thornbird, other than the gas mileage. Problems such as brakes, steering components, transmission, that type of problem.
  #8
Old 01-02-2008, 12:22 AM
redtoy92's Avatar
Pooh-Bah
Default
sounds like the lift and the miles caught up to it and those things went bad. I do not understand why you would lift and and larger tires on your truck if you drive that many miles. Just take those things out and solve all the problems. HOw often did you get your driveline lubed? did you do it or a oil change place? when was the last time you had your rear brakes inspected?
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
  #9
Old 01-02-2008, 03:26 AM
Stranger
Default
Trust me, that is not the first or the last time I will be asked why I deliver in that thing. So what you are saying is the lift itself is not what is causing the trouble, but the fact I am driving a lifted truck to deliver, and putting that many miles on it? The rear brakes were a result of me being a . I let them go longer than I should have. Is there any way I can keep the truck as is, and still put that many miles on it, or am I looking at running it into the ground soon?
  #10
Old 01-06-2008, 10:51 AM
redtoy92's Avatar
Pooh-Bah
Default
Quote:
It could have been the lift that caused the drive line but i think it was the combo of the lift, the miles, and lack of lube of the drive line. you should be fine running it like that with the lift. But you WILL RUIN INTO MORE WEAR AND TEAR. So that is all part of the game. If you want to play you will have to pay. How often to you lube the driveline of your truck.
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
