| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Toyota Tacoma Toyota Tacoma |
05-23-2007, 10:37 PM
|  | Stranger | | | Join Date: May 2007
| | front diff I am running a 98 Tacoma, 3.5" lift, 5 speed manual, on 33's. my truck has just about every mod i need, from the supercharger through the exhaust. i am looking at going with 4.56 gearing but am having trouble finding a new front diff. i have been to at least 30 off-road sites and the only thing i can find is SAS kits that i am not interested in. any help on where to locate front taco diffs would be great. |
05-24-2007, 11:40 AM
|  | Pooh-Bah | | | Join Date: Jun 2003 Location: HOME!!
| | Quote:
Originally Posted by Guilford I am running a 98 Tacoma, 3.5" lift, 5 speed manual, on 33's. my truck has just about every mod i need, from the supercharger through the exhaust. i am looking at going with 4.56 gearing but am having trouble finding a new front diff. i have been to at least 30 off-road sites and the only thing i can find is SAS kits that i am not interested in. any help on where to locate front taco diffs would be great. | so you need the outside body(aka clam shell) or do you need just the gears? I am very confussed on what it is you are looking for. YOu can keep your front diff and just swap gears.. What is it you need?
__________________
03 ext.cab v-6
charger+ URD kit+4in DP
6inch fabtech+ 1in RB
35'BFG mud+15x10 crome optimas 4.88's
stubbs sliders
rhino lining
05-25-2007, 03:22 PM
| | i cant find anyone that sells the front diff re-geared as an assembly, that is what i am looking for. |
05-26-2007, 02:42 PM
| | why would you want that? it would cost the same to just have them switch the gears in your current diff. The front diff is not the classic third member that just comes in and out like the rear and the old 85 and older fronts. It is a clamshell style that requires the front to be taken apart to switch the gears or the whole thing like you want. Just get the gears and an install kit and have someone do it.
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
05-26-2007, 06:26 PM
| | for a couple reasons, one you have already answered yourself.
i already knew what was needed to be done to remove and install the IFS diff, the time difference between just swapping out the diff and dropping it and rebuilding it, then reinstalling it is about a few hours and no warranty.
the other reason is because i would have a spare front diff if the one i swap in breaks, i can give the old diff a good ol acid bath, rebuild it and have it in my truck when i need it.
i know i can re-gear it, but not the point or the question. the question i am looking for an answer for is:
Q: Does anyone know where i can buy a complete front diff assembly with 4:56 gearing?
A: ???
i have looked everywhere and cant find anyone that sells them, at least re-geared anyways, not a very big market right now.
98 taco 4x4 |
05-27-2007, 11:00 AM
| | Yes it would be a few more hours of work... and the warranty thing is simple you buy gears from a company that will give you a warranty and have them installed by a company that backs up thier labor... oh look now you do have a warranty on your front diff.
I like your idea of a spare but 99% it will not be your front diff that has a breakage in your front end. so a spare is over kill unless you are made rock crawling(which i know is not the case having IFS) or you have a sand runner doing huge jumps.
So to answer your question... and why the market is not big for a front diff with gears on a tacoma... well a couple reasons but i already answered them myself just above in this post.
If I knew of anyone that did sale this I would tell you but I don't. I am sure you can call someplace like all pro ,marlin crawler, trialmaster and see if they would be willing to make you a custom set up.. or you can go to a junk yard, a yota dealership, or find someone who is doind a SAS and get a front diff and then do the gears on it.
and If you do find someone who sales it like you want let me know..
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
05-31-2007, 11:28 AM
| | wasn't trying to be rude in my last post, was in a big rush. i am in the military, and in Iraq so time means a lot to me, and getting things done faster means i get more play time when i am home.
i will most likely end up buying a new front diff and re-gearing it, my wifes 98 4runner is basically getting the same work i put into my taco, minus the charger so getting a 2nd front diff sort of pans out there also, she is getting the same gear ratio that i am going to be using 4:56.
i do thank you for the information though, i have already tried all of the most common places, will probably end up just getting er done at a local shop when i return.... |
05-31-2007, 09:57 PM
| | no prob.. I also was in the military in iraq and afgan at one time. I am not. Yeah it is just the way it is.. Thanks for serving. Go to the TTORA.com site and look in the for sale section ... they have front diffs all the time for sale used. You are very welcome for the info and sorry if i sounded rude also.
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
06-07-2007, 06:33 PM
| | Quote:
Originally Posted by Guilford wasn't trying to be rude in my last post, was in a big rush. i am in the military, and in Iraq so time means a lot to me, and getting things done faster means i get more play time when i am home.
i do thank you for the information though, i have already tried all of the most common places, will probably end up just getting er done at a local shop when i return.... | here you go... found you a front diff that would work perfect for a spare if regeared.. gears, front diff, misc - TTORA Forum
__________________
03 ext.cab v-6
stubbs sliders
rhino lining
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 01:50 AM. |
