ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 03-02-2007, 11:41 AM
haireball is an unknown quantity at this point
Default Rear Axle Seal
Toyota has replaced my left rear axle seal 4 times, it keeps leaking in about 10k, my right one just went at 85k because the bearing was worn so i replaced both myself this time. Has anyone else had any problems.
Old 03-03-2007, 11:18 AM
redtoy92's Avatar
Pooh-Bah
redtoy92 is on a distinguished road
Default
maybe your axle is bent or something like that... Let me look into it and I will post again later with more info
__________________
03 ext.cab v-6
charger+ URD kit+4in DP
6inch fabtech+ 1in RB
35'BFG mud+15x10 crome optimas 4.88's
stubbs sliders
rhino lining
Old 03-03-2007, 03:35 PM
mudrunner88's Avatar
Administrator
mudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond repute
Default
Quote:
Take the vent valve out of the top of the axle housing near the 3rd member. Make sure it's nice and clean and re-install it. If you axle can't breathe the pressure builds up and leaks out of the seals because that's the weakest point. Some of us in the truck/suv section install an adapter into the axle and run vac. hose up into the frame area with a filter for added protection against mud/dirt/and sucking in water during crossings.
__________________
1985 4Runner EFI 36x12.50 Swampers
Running ZUK installed 5.29's www.gearinstalls.com
Old 03-05-2007, 10:30 AM
Default
Quote:
I did put an extention on the breather and Toyota put a new breather on last time they did the seal, didn't go thru any mud since, and it leaked again, but i will pull it off and check it.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
