Quote:
Originally Posted by mudrunner88 Take the vent valve out of the top of the axle housing near the 3rd member. Make sure it's nice and clean and re-install it. If you axle can't breathe the pressure builds up and leaks out of the seals because that's the weakest point. Some of us in the truck/suv section install an adapter into the axle and run vac. hose up into the frame area with a filter for added protection against mud/dirt/and sucking in water during crossings. |
I did put an extention on the breather and Toyota put a new breather on last time they did the seal, didn't go thru any mud since, and it leaked again, but i will pull it off and check it.
