ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 09-02-2006, 12:38 AM
Str8lin
Default 06 Tacoma Tire Pressure system - disarm OR???
Hi Group:
I have an 06 Tacoma 4X4 TRD w/ the tire pressure sensors that give indication when tire is losing air. I replaced my tires and wheels last week and had not had an indication from system till yesterday when it lit up. Keep in mind that the only sensor left (radio transmitter in valve stem) is on the spare. I could not reinitialize the system.
Since I do offroad and airdown the tires, it will be a pain to deal with this and what I term useless system. Sure grandma may benefit, but I do not need this.
I am going back to my tire dealer tomorrow to try to fit all the 4 transmitter valve stems on my aftermarket wheels (American Racing Mohave Teflon 16X8). If that doesn't get ne back to "normal" without blinking dash light, then next step will be to try to get to dash light and remove.
Any ideas?????????????????
Thanks,
Old 09-02-2006, 07:23 AM
Flash550's Avatar
Stranger
Flash550 is an unknown quantity at this point
Default Re: 06 Tacoma Tire Pressure system - disarm OR???
I would try to recal it with just the one sensor. Or just look for the fuse or power wire. maybe even a relay. If you can get a wiring diagram you can see if maybe ground the wire or not keeping it open will do it.
Hope this helps alittle.
Jeff
Old 10-13-2006, 08:47 AM
Flash550's Avatar
Stranger
Here you go Toyota Nation has how to disable it.
http://www.toyotanation.com/forum/sh...d.php?t=124871
Jeff
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
