ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 03-02-2006, 11:50 PM
BirdmanP's Avatar
Newbie
BirdmanP is an unknown quantity at this point
Default Cable Concern
Does anyone know if Tacoma speedometer cables slides out of thier sheathes? I know Hondas and some Toyota cars will slide right out if you take the fitting loose from the tranny, and yank on the end of the cable with a pair of pliers. I need to grease mine and don't want to damage it trying. I figure someone else has probably tried it and has suffered that hardship...if there is one.
Old 03-03-2006, 02:44 AM
brayboy is an unknown quantity at this point
Default Re: Cable Concern
I don't think that they do. Well, at least with any success. I've heard once they start making 'the' noise, replacement is the only answer. Bray
Old 03-10-2006, 04:59 PM
monkey's Avatar
monkey is an unknown quantity at this point
Has anyone had issues of getting water inside their speedo cables? Mine makes quite a bit of noise, but only when it's around 25degrees or below, and it starts making the noise generally at about 35mph and up, regardless of what gear it's in.
I'm pretty sure it's ice in the cable. If I let it warm up about 15 minues, then let it sit for about 15 minutes with the engine off before I go anywhere, it doesn't do it.
But, who wants to wait 30 minutes to go anywhere???
What's the easiest way to get some lube in there, and should I use lithium grease, graphite, or what?
Sorry, I'm not trying to hijack your thread, it's kind of the same issue, lol
Old 03-10-2006, 08:31 PM
BirdmanP's Avatar
Newbie
I tried graphite. It was suggested in a previous thread, but I couldn't get anything in the cable end. I used a spray white lube, and it worked for about a month. I've got some great heavy duty chain lube, but don't have a nozzle to get in the cable end. I figure next time I get in there I'm gonna have to engineer something.
  #5
Old 03-14-2006, 02:04 AM
[ QUOTE ]
I'll just have to bump this thread 2 posts up. Bray
  #6
Old 04-01-2006, 09:26 PM
Newbie
bowyer2002 is an unknown quantity at this point
I have used a motorcycle cable lube tool to lube cables without having to remove them from the housing. For the lubricant use something that will leave the right residue (teflon or silicon) like TRI-FLO aresol.
These lube tools are available at motorcycle shops ($20) and look like this:
http://cgi.ebay.com/ebaymotors/CABLE-LUB...sspagenameZWDVW
this beats the heck out of removing the entire cable and re-inserting it into the housing!
good luck!!!
  #7
Old 04-02-2006, 12:34 AM
BirdmanP's Avatar
Newbie
Freakin' Sweet Dude. I'm givin you props on that one. You may have just solved my $70 Dollar dilemma!!!
  #8
Old 04-03-2006, 12:22 AM
monkey's Avatar
Awesome idea!! Thanks Bowyer2002!!
  #9
Old 04-11-2006, 09:57 PM
BirdmanP's Avatar
Newbie
I bought one of those lube tools. Didn't work. No let down, I'm sure I can use it on my 4wheeler or rail buggy. The housing is just so friggin huge on the 'yota. The squeek is starting to die down with the weather so I've got some time to figure something out. I'll post back when I do, or when I don't, either one.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride.
