dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Toyota Tacoma Toyota Tacoma |
03-02-2006, 11:50 PM
|  | Newbie | | | Join Date: Oct 2005 Location: Spartanburg, SC
| | Cable Concern Does anyone know if Tacoma speedometer cables slides out of thier sheathes? I know Hondas and some Toyota cars will slide right out if you take the fitting loose from the tranny, and yank on the end of the cable with a pair of pliers. I need to grease mine and don't want to damage it trying. I figure someone else has probably tried it and has suffered that hardship...if there is one. |
03-03-2006, 02:44 AM
| | Old Hand | | | Join Date: Dec 2003 Location: Montgomery, Alabama
| | Re: Cable Concern I don't think that they do. Well, at least with any success. I've heard once they start making 'the' noise, replacement is the only answer. Bray |
03-10-2006, 04:59 PM
|  | Enthusiast | | | Join Date: May 2005 Location: Idaho, USA, Earth
| | Re: Cable Concern Has anyone had issues of getting water inside their speedo cables? Mine makes quite a bit of noise, but only when it's around 25degrees or below, and it starts making the noise generally at about 35mph and up, regardless of what gear it's in.
I'm pretty sure it's ice in the cable. If I let it warm up about 15 minues, then let it sit for about 15 minutes with the engine off before I go anywhere, it doesn't do it.
But, who wants to wait 30 minutes to go anywhere???
What's the easiest way to get some lube in there, and should I use lithium grease, graphite, or what?
Sorry, I'm not trying to hijack your thread, it's kind of the same issue, lol |
03-10-2006, 08:31 PM
| | Re: Cable Concern I tried graphite. It was suggested in a previous thread, but I couldn't get anything in the cable end. I used a spray white lube, and it worked for about a month. I've got some great heavy duty chain lube, but don't have a nozzle to get in the cable end. I figure next time I get in there I'm gonna have to engineer something. |
03-14-2006, 02:04 AM
| | Re: Cable Concern [ QUOTE ]
I'll just have to bump this thread 2 posts up. Bray |
04-01-2006, 09:26 PM
| | Newbie | | | Join Date: Jan 2005 Location: missouri, USA
| | Re: Cable Concern I have used a motorcycle cable lube tool to lube cables without having to remove them from the housing. For the lubricant use something that will leave the right residue (teflon or silicon) like TRI-FLO aresol.
These lube tools are available at motorcycle shops ($20) and look like this: http://cgi.ebay.com/ebaymotors/CABLE-LUB...sspagenameZWDVW
this beats the heck out of removing the entire cable and re-inserting it into the housing!
good luck!!! |
04-02-2006, 12:34 AM
| | Re: Cable Concern Freakin' Sweet Dude. I'm givin you props on that one. You may have just solved my $70 Dollar dilemma!!! |
04-03-2006, 12:22 AM
| | Re: Cable Concern Awesome idea!! Thanks Bowyer2002!! |
04-11-2006, 09:57 PM
| | Re: Cable Concern I bought one of those lube tools. Didn't work. No let down, I'm sure I can use it on my 4wheeler or rail buggy. The housing is just so friggin huge on the 'yota. The squeek is starting to die down with the weather so I've got some time to figure something out. I'll post back when I do, or when I don't, either one. | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride. All times are GMT -5. The time now is 09:55 PM. |
