ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 01-30-2006, 04:57 PM
Aprentice
TankRD is an unknown quantity at this point
Default CV boot
I have had the daystar 2.5 lift kit for only a couple of months now and my cv boot is already leaking. Has anybody else had this problem? I only have 43000 miles
does factory warranty cover this if not how much $$$
Thanks
Old 01-30-2006, 06:11 PM
Stranger
jthayer81 is an unknown quantity at this point
Default Re: CV boot
I'd guess the dealer will tell you your S.O.L.
The $ depends, if its just the boots your pritty much just payin for labor, maybe $100 per side.
But if its the joint then tack on another $150-$200 per side
Old 02-02-2006, 10:34 AM
haireball is an unknown quantity at this point
Default Re: CV boot
Drivetrain should be 70k, but the boot is questionable, you can call a dealer and ask. yeah i would remove the lift before i took it in if you think that is what caused it. i have 2.5" Puck lift with diff drop and no problems yet with about 40k miles with it on
Old 02-04-2006, 12:01 PM
Aprentice
Default Re: CV boot
I took my truck in to get it looked at and found my front left axle seal left rear wheel cylinder and inner cv boot leaking. Everything except my cv boot is covered by factory warranty. Good news is that my extended warranty thru my bank covered it. They also replaced my shifter bushing under warranty.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
