ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 12-22-2005, 12:26 PM
BirdmanP's Avatar
Newbie
BirdmanP is an unknown quantity at this point
Default Exhaust Gaskets
Ok Guys, I've got a problem. I put a Pacesetter header (big mistake) on my truck (2.7L). I welded the collector up on it already b/c it wouldn't stay sealed for longer than a week. So it didn't leak for a while after that but now I have a new problem. Where the header bolts to the cat won't stop leaking. Since I built a flange form scratch when I put a high-flow cat on it, the factory asbestos crush ring won't work. I tried Mr. Gasket exhaust gasket material and I feel I could do better with a tube of RTV! The material gets so hot it just burns out. So my question is: Where can I find a good, thick, high temp gasket material to make a gasket from?
Old 12-26-2005, 03:47 PM
brayboy is an unknown quantity at this point
Default Re: Exhaust Gaskets
Try a lot of Permatex High-Temp copper silicone sealant. Good luck. Bray
Old 12-29-2005, 02:56 AM
Journeyman
BruceBruce is an unknown quantity at this point
I saw some gasket material at kragen the otherday. Was a big sheet of it that you made your own gaskets out of.
Old 12-30-2005, 03:22 PM
Journeyman
TNCowboyPRCA is an unknown quantity at this point
if you gonna keep it setup with the mods like they are, then just weld everything and save your self a headache further down the road, but thats just my pennies thoughts, good luck
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
