OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 12-04-2005, 08:07 PM
gotshot
Default headlamp replacement
My headlight finally went out in my 01 tacoma. I looked at it and it has a rubber boot. when I pulled it off it wouldnt come off all the way and I could see a little clip. anyone replaced a bulb yet? any help would be appreciated.
Thanks
Old 12-04-2005, 11:03 PM
brayboy is an unknown quantity at this point
Default Re: headlamp replacement
I have a '99 but I bet it's no different than your '01. I've done it once,but forgot a little about it so I went outside (had to hurry, it's raining & lightening) but the clip-looking thing you saw is just the back of the bulb bracket. I think if you rotate this housing left (to the driver's side of the truck, It will allow you to pull the housing out to replace the bulb. Your owners manual should help you out in this situation. I hope this helped. Bray
Old 12-04-2005, 11:28 PM
WATRD's Avatar
Journeyman
WATRD is an unknown quantity at this point
Pull plug from the back of the bulb, pull the rubber boot off. Then there is a spring loaded clip you have to pop loose and the bulb will come loose from the housing.
The housing/enclosure remain in position and the bulb and H4 if I recally correctly, comes out the back. The bulb has three alignment tabs on it, so reinstalling it with the correct orientation is easy. Then reset the clip, the rubber boot and plug it back in.
Old 12-04-2005, 11:56 PM
Journeyman
BruceBruce is an unknown quantity at this point
www.customtacos.com has a write up on replacing the headlights in the tech articles. Just the bulb part.
  #5
Old 12-05-2005, 11:32 AM
liquidvw
If you can't find H4. 9003 will work also. Same watage.
  #6
Old 12-05-2005, 06:32 PM
gotshot
Thanks alot I knew it would be easy just didnt want to break anything. Thanks
  #7
Old 12-06-2005, 09:01 AM
liquidvw
Another note for your fist time changing the bulbs. DONT TOUCH the glass on the bulb. Very important. If you do, the oils on your fingers will stick to the glass. The oil will heat up and cause the bulb to fail.
  #8
Old 12-06-2005, 10:26 AM
haireball is an unknown quantity at this point
yeah and the clips are a pain in the butt, the first few times i had trouble with it, but i can do it with my eyes closed now, I kept buying those high output bulbs, they are nice, but didn't last long
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
