OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 11-21-2005, 07:24 PM
Stranger
fumey is an unknown quantity at this point
Default P0420 CODE
Had this code pop up about 40k miles ago, cleared it and had no problems till another 40k miles. This time , I cleared the code and it only took about 1200 miles before it showed up again. Just wondered if anybody ever actually had to replace their converter . I'm going to check the O2 sensors , maybe foul out my plugs with the sea foam treatment ( wish I'd saved the old ones -maybe now I'll try those iridiums) , clean the MAF to see if any of this helps, but I'm kind of bummed cause I think my high mileage may have cooked my cat. Should I be worried about the engine? Is there a possiblity that maybe the CPU just needs to be upgraded? Help? THanks.
Old 11-22-2005, 08:28 PM
dezert_rida is an unknown quantity at this point
Default Re: P0420 CODE
If your having a cat efficiency code, chances are the cat needs replacement. Most cats last 60-80k.
The ECU does not need to be upgraded, the cat does.
Old 11-25-2005, 12:12 PM
WATRD's Avatar
Journeyman
WATRD is an unknown quantity at this point
From the FSM, possible causes of a P0420;
 Gas leakage on exhaust system
 A/F sensor (bank 1 sensor 1)
 Heated oxygen sensor (bank 1 sensor 2)
 Three–way catalytic converter
Check your oxygen sensors before you worry about the cat.
Old 11-28-2005, 10:33 PM
BirdmanP's Avatar
Newbie
BirdmanP is an unknown quantity at this point
Good Luck. I still can't get my P0420 Code to go away. I can delete the code and it just comes back. I have done everything. New Cat, both 02 sensors, and no leaks. I did put a header on it, but I don't hink that has anything to do with it if there are no leaks. Sometimes it will stay off for weeks at a time, and sometimes it will come back in a day or two.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
