ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
  #11
Old 11-17-2005, 05:08 PM
hupptoy's Avatar
hupptoy is an unknown quantity at this point
Default Re: Intake Silencer Mod
It also takes some time for the computer to adjust to any changes made (2 miles is probably not enough), so it should adjust itself for you this weekend.
hupptoy
  #12
Old 11-17-2005, 06:32 PM
Journeyman
BruceBruce is an unknown quantity at this point
Well i got a 40 series flow dumped on my truck. I'll eventaully run headers but that wont be for atleast a couple of months cause i need to finish some other stuff first. I don't understand how you did yours though. Is their a link you followed or myabe explain/ show some pictures of what you did so i can visualize it better. Looking forward to your update on it after this weekend though.
  #13
Old 11-17-2005, 10:56 PM
monkey's Avatar
monkey is an unknown quantity at this point
I used this site:
http://www.yotatech.com/~corey/tech/...r/96runner.htm
His measurements were off for mine, though. All I have (had) is the "J" tube, and one big box. They both took a 1-1/4" PVC cap. So I had to buy those, two brass fittings that he names, and I got the new vacuum line free.
Since I had two small caps instead of a large one, I had to put the brass fittings one per cap. It still went super easy. I plugged the vacuum line from the steering to the old J tube position, and ran the new vacuum line to the other cap. The only other opening I had on my intake pipe was a big vacuum line heading around behind the throttle body. Figured I might want to leave it alone, lol!
  #14
Old 11-21-2005, 02:52 PM
monkey's Avatar
OK, I got roughly 150 miles on it this weekend, and I still can't feel much of a change. Maybe in the higher RPMs, but if it's there, it's not much. How long does it take for the 'puter to reset?
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
