ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 10-12-2005, 09:13 AM
Jadeyz250f
Default Tire size question
Hi! I am new to the forum. Looks great!
I have an '03 Double cab 4X4 TRD with a 3" lift. I was wanting to put on 285/75/16 on. Wondered if they will rub, will the ride of the truck be much more harsh, decreased gas mileage (how much lower), etc. Thanks in advance! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 10-12-2005, 12:09 PM
haireball is an unknown quantity at this point
Default Re: Tire size question
i would guess you will have rubbing issues, the width is your main problem not the height, That tire would be 33x11.5, and the 11.5 is going to run somewhere- frame, tire well pinch weld, etc...
http://www.parksoffroad.com/tacomamo...acoma.html#sus
is running 33x12.5x15, but he had pretty good lift
yes it will hurt your milage, but you have to re-add the 10% you will lose from your odometer reading incorrect, you will lose 2-3 mpg being my best guess
Old 10-14-2005, 02:36 AM
0stepside3's Avatar
Newbie
0stepside3 is an unknown quantity at this point
I've got the 285/75/16s on my xcab prerunner.... I haven't got any lift on the truck.. I did the pinch weld mod, now I have very minimal rubbing... So I would think with 3 inches of lift, it wouldn't rub... and I get 19 mpg out of the 3.4
Old 11-21-2005, 07:51 PM
Newbie
bowyer2002 is an unknown quantity at this point
i have installed 255/85 r16 cooper discoverers(33.5" x 10"+/-)on my 01 double cab (stock rims) and have not had any rubbing issues and no pinch weld modification. however, i also have an ARB brush guard and that may help with stock clearance issues in the front of the tire. i do very little extreme offroading but do use my truck for hunting which requires creek crossings & such so it really does get used as a 4x4!
also these tires are wearing great as i have 50k on them and still about 3/8" of tread left! but i rotate every 6k and keep them inflated properly too.
just my 2 cents...
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
