dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Toyota Tacoma Toyota Tacoma |
10-11-2005, 11:54 AM
| | | Highbeams & Lowbeams Is there a way to keep your lowbeams on when you turn your highbeams on. I am very farmiliar with vehicle wiring and not afraid to rip into my truck. Theres gotta be a way. Can anybody help me out. 99 Tacoma 4x4 |
10-11-2005, 02:05 PM
| | Enthusiast | | | Join Date: Jul 2003 Location: Los Angeles, CA
| | Re: Highbeams & Lowbeams Here's the deal theoretically you can do it, BUT without adding another relay and more wiring you will only get two modes of lighting. Low beam w/High beams on and High beams w/Low beams on. Even in this set up you will have to replace the wiring. If you want to be safe and trust me, you want to be safe. Fuses and wiring are usually able to handle 25% more of actual current. I can't remember but the amps are 10 for the lights.So if the fuse is 10 amps it is using 7.5 amps and it only takes 1 amp can kill you. if you don't go to a bigger wire you will must likely cause the stock wires to burn (electricity and fire don't mix). You will need to go to a heavier gauge wiring from 14 (i thinK) to 12 or 10 (10 is better) and get a bigger fuse.
I think you are better off buying some driving lights. |
10-11-2005, 04:34 PM
| | | Re: Highbeams & Lowbeams The two modes are true, and I am aware that simply bridging the two hots to each light would give you this result. Thank you for the info on the relay and heavy guage wire, but that sounds like alot of crawling up behind my dash and smashing my hands into places they dont want to fit. Especially if it requires basically a whole overhaul of the headlight wiring system. I think I will take your advice and possible go another route. Would you recommend replacing the stock highbeams with brighter bulbs? Thanks again! |
10-12-2005, 12:41 AM
| | Old Hand | | | Join Date: Dec 2003 Location: Montgomery, Alabama
| | Re: Highbeams & Lowbeams The link below may help you decide what configuration you have. You might try Downey or Northwest Offroad for a direct replacement. I hope this helps. Bray Oh! here's the link.
[img]/ubbthreads/images/graemlins/40BEER.gif[/img] |
10-12-2005, 08:38 AM
| | | Re: Highbeams & Lowbeams helps alot, thanks!! |
10-13-2005, 01:14 AM
| | Re: Highbeams & Lowbeams Your welcome. Just let us know if you have anymore questions concerning your question. Toyota wiring doesn't make sense sometimes. Bray [img]/ubbthreads/images/graemlins/40BEER.gif[/img] |
10-13-2005, 01:42 AM
|  | Newbie | | | Join Date: Sep 2005 Location: Middle Georgia
| | Re: Highbeams & Lowbeams Okay, here's the easiest way to leave your high beams and lows on at the same time without having to mess with any wires..
1. Get into the truck at night.
2. Start the truck.
3. Turn on headlights.
4. Begin driving.
5. Take your left hand, hold the headlight switch.
6. Pull the switch towards you.
7. Hold that position until you grow tired of the brightness.
[img]/ubbthreads/images/graemlins/neener.gif[/img]
Sorry, I just had to do it |
10-13-2005, 09:25 AM
| | Enthusiast | | | Join Date: Aug 2004 Location: Central PA
| | Re: Highbeams & Lowbeams My sister borrowed my truck one night and she was all mad b/c she had to hold the stick back the whole time she wanted hi-beams......
I was like did you try pushing it forward...lol |
10-13-2005, 12:37 PM
| | Re: Highbeams & Lowbeams hahaha, Girls! You should have told her to check the hi-beam fluid, maybe it was empty. Did she tell you the 701 cap come off. (710=OIL upside down) |
10-16-2005, 03:22 AM
| | Re: Highbeams & Lowbeams Man I'm always a couple of days late responding on the board, but this is funny! Bray [img]/ubbthreads/images/graemlins/thumbsup.gif[/img] | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride. All times are GMT -5. The time now is 09:30 PM. |
