ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 09-16-2005, 12:20 PM
29Palms
Default Gas Mileage
Wow 14MPG@ 75 Mile per hr on the freeway (thats how fast I drive to and from home 145 miles each way)
Is that right.
I had replaced the timing belt, both oxigen sensers,wires, plugs, fuel filter,air filter and the mileage still is 14 mpg.
I have 90,000 miles on it and the mileage dropped off at about the 75-80K mileage mark.
The front end is aligned and I keep my tires aired up.
Anybody got any ideas?
Jerry [img]/ubbthreads/images/graemlins/wall.gif[/img] [img]/ubbthreads/images/graemlins/wall.gif[/img]
Old 09-16-2005, 11:29 PM
Hooyahdiver
Default Re: Gas Mileage
Have you checked that there's no binding in the drivetrain? Checked and changed your diff, tranny and transfer case fluids since you've had it? Are you using the proper weight motor oil for the climate where you live? I put a lift kit and larger tires on my 2000 Tacoma and it dropped from about 21MPG to 18MPG. 14MPG is absurd. Good luck with figuring it out.
Old 09-18-2005, 11:23 PM
Journeyman
BruceBruce is an unknown quantity at this point
That sucks, I have a 2001 v6, and i got 20mpg on the freeway at 75-80 on a 300mile trip to sierra summit. After doing an exhaust and intake i got like 21.5 to san diego. You can try switching to synthetic blend motor oil or full synthetic. It helped me out a little bit. going to synthetic blend. Switching to full next oil change.
Old 09-19-2005, 04:49 PM
29Palms
I must have gotten bad gas for the last 6 weeks.
I must mention I have the v6 5 speed, anyway this last tank I figured I got 20 mpg.
The tank before I got 17 mpg, the previous one gave me 14 the gas mileage had been dropping and I made those part replacements like I had said in my first post.
Now can it be the rotten gas from california?
  #5
Old 09-20-2005, 10:46 AM
29Palms
OK New update
I filled it up last night and got 17.9 mpg.
It must be the Southern Cal Gas in Orange county [img]/ubbthreads/images/graemlins/cussing.gif[/img]
  #6
Old 09-20-2005, 04:05 PM
haireball is an unknown quantity at this point
I have problems if i go over 70 mph, my milage drops like a rock, I got 21-22mpg highway if i kept it under 70 and 16mpg at 75 mph. Now i have a 2" lift and mts and get about 19 highway with 73k
V6 5speed xcab 4x4
  #7
Old 09-20-2005, 04:21 PM
HarveysTacoma's Avatar
Stranger
HarveysTacoma is an unknown quantity at this point
I have a 96 tacoma sx with a 3" toytec spacer. It averages around 16mpg after lifting it only because its not aligned yet but once I do that it should be back to normal. Does anyone know if the tornado would work? (to save on mileage) Also how many miles could be on a truck before it is to late for synthetic?
  #8
Old 09-21-2005, 01:23 AM
Journeyman
Theres a time thats too late to add full synthetic?
  #9
Old 09-21-2005, 08:54 AM
liquidvw
I don't think it is ever to late to add synthetic. But I would think it would be a bad idea to switch back and forth. Pick one and stick with it.
  #10
Old 09-21-2005, 11:14 AM
29Palms
I think this weekend I will try my damdest to keep it down under 70 mph.
I took the scanner home last night and found no codes. I also observed the action from both oxigen sensers and I guess all is ok.
I wonder if the front drive could be dragging the truck down or something.
Anyway I also dont think switching to synthitic oil is the answer. I want to correct the problem and then start to change stuff. I got mileage in the 20s without synthitic oil when I first got this truck.
I'll let you know.
I had a 1997 toyota pickup with a 4 cyl 5 speed 2by and got 34 mpg.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
