Hupptoy-Thanks for clarifying that again.
Yotasalker-Your suspension lift just messes with the geometry of the suspension. The lift kit I am telling you as a cure is a body lift kit. It simply replaces the body pucks with taller ones. It does not even touch the suspension. The body lift kit will raise the body only. Guys will use a body lift as a cheap way to gain tire clerance some times. Roger Brown at
4Crawler makes then for cheap. It will clear the SC'er and gove you more tire clearance for taller tires. I run a 1" to clear my from bumper and have had no problems.
