Re: tires?.....foreign subject.... You setup will work with the 3in lift and 32s on the stock wheels. You will notice when at full turn you tire will rub the frame slightly because of the increased width and height.
But it will not cause any damage, just wear the paint off the frame rail. You can prevent it by just not turning so sharp. Or you can always lengthen your steering stops by a tad bit so you can't turn as sharp, if the rubbing bothers you. It will be so minute that it won't really effect your turning radius at all |
