ADVERTISEMENT
Toyota Tacoma Toyota Tacoma
Old 05-05-2004, 01:52 AM
Hampster
Default 33x12.50 Pro Comp X Terrains Tire Pressure?
Just put these on my tacoma. I know the owners manual said 26 for the front and 29 rear for the stock 31 inch tires. What do you all run for tire pressure for normal driving? I would like it to have a good contact pattern so it will have even tread wear. Also, since i put the tires on the truck pulls to the left. It had an alignment back in january and was tracking straight before they were put on. has anyone experienced this? Also, they are on 15x8 rims.
Old 05-06-2004, 10:29 PM
Hampster
Default Re: 33x12.50 Pro Comp X Terrains Tire Pressure?
no one can help me?
Old 05-06-2004, 11:16 PM
broken is an unknown quantity at this point
hell id run 35psi on road and off road i run 15psi and that is what i do with my stock taco tires and 31inch BFGs do what ever the tire says just listen to the tire it will tell you [img]images/graemlins/bs.gif[/img]
Old 05-06-2004, 11:55 PM
4x4taco
taco's are pretty light so you don't need to pump 'em up too high. run them at about 35psi for a few thousand miles and if you start to notice uneven wear between the middle and sides of the tread, change the pressure. if the sides are wearing faster (doubtful), run a slightly higher pressure to 'balloon' the tire, and if the middle is wearing faster, lower the pressure to reduce ballooning and wear the sides more. and run 'em where they're comfortable, within reason obviously, mine rides much better at 30psi than 35psi
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
