high rpm chugging on my 22re...HELP - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Toyota > Toyota SUV's & Trucks
Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's
Old 05-14-2008, 10:03 AM
dillsmack
Default high rpm chugging on my 22re...HELP
I'll just give the symptoms and hope someone can help. (the vehicle is an 89 4runner with an EFI 22re and manual trans) It seems to me that the engine is bogging out at higher rpms, right before when you would shift on regular on-road use (I don't have an rpm gauge but i would guess around 3 grand). When this happens it loses all power and i am forced to shift prematurely just to keep it moving. Chugging would be a good word to describe the feeling and sound of the engine. Also I'm getting a massive odor of gas at the time of the chugging. The engine also idles very rough and often very low and the idle is adjusted to the max and still very low and rough. I had this problem before and adjusted the idle and replace an obviously bad dash pot, the problem seemed to be fixed but now is back and the battery light and brake lights now stay on, (not the check engine light though). Ideas? Things I can try? I thought the TPS, maybe a clogged fuel filter, but i really don't know.
Old 05-14-2008, 06:55 PM
mudrunner88's Avatar
mudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond repute
Default
Do a search for TPS (throttle position sensor) and follow the steps to test it with an ohm meter and feeler gauges. If it fails replace it with one that passes you can use junk yard ones as long as it passes the test. They are a little pricey if you get them new.
__________________
Offroad Toyotas
Old 05-14-2008, 08:58 PM
missouriman has a spectacular aura aboutmissouriman has a spectacular aura about
Default
yep tsp or mas has taken a dump on you.
for the gas smell I would guess a short.
__________________
http://www.bh4wheelers.com/
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
