dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's |
08-24-2009, 06:49 PM
| | Old Hand | | Join Date: Mar 2003 Location: Fairbanks, Alaska
| | 22 R-E engine question, is it time for a new one.
Hello, this is my first time posting here but I am a regular over on the Jeep board. I could use some information on Toyota engines if you could be so kind.
My brother has a 93 Toyota pickup with a 4 cylinder 22 R-E engine. Recently it began running rough, the mechanic says the time timing chain has skipped 2 teeth, and he needs a new engine.
Now the timing chain skipping matches the symptoms so that makes sense. But I do not see how this could lead to the whole engine needing to be replaced. If the chain had broken I could see now the pistons may have hit the valves and needing a new head or rebuilt, but I would not think skipping 2 teeth would be out of time enough to cause the valves to hit.
I guess what I am asking here is does the mechanics opinion sound correct, would this really cause the engine to be totalled? Saidly I live to far from my brother to look at it myself.
Thanks,
__________________
Wilhelm
08-25-2009, 12:00 AM
|  | Keyboard Implanted | | Join Date: Sep 1999 Location: Casa Grande, AZ
| | Quote:
Originally Posted by bandhmo2 Hello, this is my first time posting here but I am a regular over on the Jeep board. I could use some information on Toyota engines if you could be so kind.
Thanks, | How does the "mechanic" know that the TC has skipped 2 teeth? Which teeth?
If the TC is off 2 teeth on the top cam sprocket that would make the cam timing off about 18 degrees - advanced or retarded, depending on which direction the chain "skipped" - I don't think the engine would even run. One negative effect if two teeth skipped on the crank sprocket would have is ignition timing. Timing chains on these engines can go "bad" and not require a "new engine".
If the TC is loose enough to skip over the sprocket, it should be making one helluv noise and probably has worn through the side of the timing cover. What typically wears out are the two chain dampers one each side of the chain, allowing the steel chain to flop against the inside of the alloy timing cover, which wears a groove in it fairly quickly.
I think your brother should get another opinion.
__________________
gNARLS
08-25-2009, 12:33 AM
|  | Keyboard Implanted | | Join Date: Nov 2001 Location: SF Bay Area, California, USA
As long as the valves are still intact, should not be any engine damage. Check the timing chain and replace it if needed. There is a writeup on that in the Toyota section here.
09-02-2009, 07:19 PM
| | Newbie | | Join Date: Sep 2009 Location: South Carolina
Skipping two teeth sounds unbelievable. How exactly would it manage to do this? Just curious. Any other indications that led the mechanic to this conclusion? I mean, lots of things can make an engine run rough.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 02:53 AM. |
