Quote:
Originally Posted by NMMarauder After I posted this, I thought of a better way to phrase my question.
Let's say you were part of a contest and in the contest they gave you a stock 1994 22re 4x4 and say $4000 in cash that you could use to modify it. Then they were going to send you on a cross country trip down forest roads, logging roads, highways, and the occasional deer trail. What would you spend your 4K on?
I'll take a stab at answering it and maybe some more experienced wheelers will chime in. - I'd do something about the stock diffs. It seems to me that having all four wheels driving even if they were stock tires would be better than having two 33 inch mud tires driving. It seems not getting stuck in the first place would be better than recovery afterward. A truetrac for the front end runs about $420. A soft locker for the rear runs $628. (I'm not attached to these choices. I'm just picking them for sake of comparison) I have no idea how much it would cost to install them (or how hard it is to do it yourself) so I'll guess $400 to get the both installed. (I may be way off)
- I'd buy a wench and its associated equipment next. You will need a bumper to mount it to. I'm guessing $675 for the bumper if you install it yourself. $900 for a winch and associated straps
- With only a $1000 left I guess I would get the largest tire that would fit under without a lift kit. So maybe $600 for tires. Toss in a high lift jack $70, shovel $40, maybe some tire chains $100 and that would be most of the 4K. Just about $250 left.
I did a quick search for lift kits but I couldn't really figure out what all is needed. Anyone have a ballpark figure on the lift kit? Could you do it for $250? Would you spend it on something else? I guess you could by 42 six packs instead.
Thoughts are welcome. Are my numbers totally off? |
Verty interesting topic...!! I'm sure you will get a wide range of viewpoints and experiences.
Numbers $$$ can vary.
I think you thought it out well.
NOT-STUCK is way better than UN-STUCK. The Boy Scout moto: BE PREPARED works really well.
Not getting stuck is important if you’re out solo. Here in AZ, you could find yourself in some potential danger without proper gear or water. When I first moved to AZ, I took my Toy truck out exploring quite a few times by myself. I always told my wife where I planned to go, how long I intended to be out, and left her the topo maps of my intended route. Although I had a cell phone and CB, it wasn’t always in range. I packed plenty of bottled water and food. I carried a gun, and a change of clothes and wore a good pair of boots, and a small back pack. Fortunately, I never got “stuck” or broke down while out by myself.
I have a friend that 4-wheeled into a trail and got stuck and had to walk out about 12 miles… that took him almost all day!! Walking out of 4x trail is a little slower than walking down a sidewalk.
Before I had lockers (essentially 2 wheel drive), suspension, and aggressive off-road tires, I just used my head and my gut. If something didn’t look good, I just didn’t go through it or over it. After lockers, tires, and suspension parts, then I got a little more daring.
Lockers are probably the best mechanical asset you can have on 4x4 for traction. Good tires are obviously important. Then some body armor.
If I were going to go out in the “boonies” exploring now, by myself or just me and my wife, I’d have a good winch, extra cable, and snatch strap. I’ve always carried three tool boxes full of my tools, extra parts, cans of motor oil, a CO2 tank for airing up the tires. Since my trucks have been white, I carried two cans of florescent red paint. Before I had a GPS, if I were going into an unfamiliar trail, I’d reach down out my door or get out and spray a 6" circle on a rock where I turned. I also figured that if I ever got stuck or injured and had to stayed with my truck, in an emergency I would spray the top cab and hood with “help” in big letters – in case someone sent out some aircraft.
Bare minimum I carried before I had a winch was a come-along with extra cable and a hi-lift. An
8K winch on these little trucks adds some weight on the front end. My Ramsey 8000, with just the bare mounts weighed 163 lbs!! It was very noticable on my 1986 Long Bed IFS.
So, if it were my truck, I'd do a rear locker first, then some larger more aggressive tires (keeping in mind it's my daily driver) Next I'd put a locker in the front. My next purchase would be a Marlin Crawler. Then a winch.
Airing down the tires can have a dramatic effect on traction-not to mention smoothing out your ride! On my Toy trucks, I usually aired down my 33" BFG Muds to 10 lbs. as a start for most wheeling. In the sand, mud and snow I'd go down to 5 lbs. I have gone many miles on the highway at 10 lbs, driving under 60 with no problem, but I don't think it's safe to do, and it's better to air back up. My 20 lb. aluminum CO2 tank will fill up my 33" between 50 and 60 times on one tank. I could fill up all 4 33's from 10 lbs to 25 lbs in less than 5 minutes. Depending on the ambient air temp, the 4th tire goes a little slower because the CO2 gauges tend to freeze up.
That's just my worthless opinion.
