ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Toyota > Toyota SUV's & Trucks
Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's
Old 12-21-2008, 01:52 PM
JEFFB is an unknown quantity at this point
Default Window Channel Molding & Door Weatherstrip
Anyone know where I can get replacement Window Channel molding and / or the weather strip (outside / inside rubber seal between door and window) ?
I know JC Whitney has some stuff but I am looking for a made to fit kit.
__________________
JeffB
84 ExtCab SR5, Detroit (Rear), LCE Headers,
DOA Cam (C270), Weber (32/36), AllPro Bumpers,
V6 Brake Upgrade
Old 12-21-2008, 03:28 PM
Nodaknova's Avatar
Apprentice
Nodaknova is an unknown quantity at this point
Default
Rockauto for the door seals, you can buy them directly from metrommp, but there is about a $30 price difference
METRO Part # LM135 More Info
Molded Door Seals. Pair R&L $74.79
* Non-stock item--shipping delayed up to 2 business days
I've seen the window channels somewhere...if I can find or remember, I'll update
Old 12-22-2008, 09:02 AM
Default
Thanks, I checked out Metrommp (metrommp.com) and the LM135 (door jam seal) part is not what I am looking for. I'm looking for the rubber strip that is located where the door glass comes out of the door. There is a inner and outer rubber strip that clips into the door sealing the area between the door metal and window glass. The glass slides through the inner and outer weather strip.
I am also looking for the rubber door window channel that the glass rides in. It plugs into the channel that goes around the inside channel of the door extends doown inside the door.
I think I found the door weather strips at Carparts.com but need to call them because they do not specify wheather they are inside or outside door strips.
So far only JC Whitney has the window channel that may work, but requires custom cutting and fitting.
__________________
JeffB
V6 Brake Upgrade
Old 01-08-2009, 09:17 PM
Tonka's Avatar
Aprentice
Tonka is an unknown quantity at this point
Default
buy it from the dealer. Toyota of Dallas has a website you can order from:
Genuine Toyota Parts and Accessories wholesale to the public.
or you can call them direct: 1-866-233-4305
__________________
Thanks,
Rod
www.crazypetersons.com
TLCA # 9116
TTR #013
  #5
Old 03-14-2009, 03:17 AM
Stranger
bendixg is on a distinguished road
Default
I think you could buy is some dealers or at toyota dealers for that molding dude....
_________________
Rapid Manufacturing
  #6
Old 10-01-2009, 02:25 AM
ema ema is offline
Novice
ema is on a distinguished road
Default
JEFFB, if you're still in need of toyota replacement parts, check out that link. They give good deals for replacements. There, but I hope you already solved your problem.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
