ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Toyota > Toyota SUV's & Trucks
Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's
Old 05-05-2008, 10:34 AM
JEFFB is an unknown quantity at this point
Default Load Sensing Proportioning Valve
Anyone know where I can get a LSPV for a 1984 Truck 4WD, except from the stealership ?
__________________
JeffB
84 ExtCab SR5, Detroit (Rear), LCE Headers,
DOA Cam (C270), Weber (32/36), AllPro Bumpers,
V6 Brake Upgrade
Old 05-05-2008, 03:26 PM
4Crawler's Avatar
4Crawler has a spectacular aura about4Crawler has a spectacular aura about
Default
Quote:
Junkyard or Car-Part.com--Used Auto Parts Market for a used one.
Old 05-06-2008, 08:01 AM
Default
Quote:
Roger thanks for the link, I would have to contact them since they do not list the part in their parts list breakdown. I would have to question the condition of the part since it is used. I found a new part from a toyota discount parts house at an acceptable price.
Has anyone ever rebuilt a LSPV, can they be rebuilt ?
I am definently keeping my old one.
Finding older toyota's in junk yards in my area is usally a waste of time, they are sent oversea's as soon as they come in.
__________________
JeffB
V6 Brake Upgrade
Old 06-25-2008, 10:40 PM
tygern8r
Default Lspv
Front Range Off-Road makes a nice aftermarket adjustable one.
Front Range Off-Road Fabrication
Don't have one myself, but some guys over at Pirate do. It looks like you mount it up by the master cylinder and it's adjustable, too.
  #5
Old 08-06-2008, 01:43 AM
4x4mike is an unknown quantity at this point
Default
Is yours toast? Serviceable? I think I remember reading somewhere about servicing them. Maybe 4x4wire.
__________________
1990 K1500 Long Bed,Auto,350,add-a-leaf/t-bar,2" PA Body Lift,K&N,Magnaflow, 285 BFG T/A KO, York OBA, 14 bolt SF w/ Detroit
  #6
Old 08-06-2008, 01:13 PM
Tonka's Avatar
Aprentice
Tonka is an unknown quantity at this point
Default
I removed my LSPV and put in an adjustable unit by the Brake Booster in the engine bay.
It took a little while to adjust it properly, but it is now dialed in.
I bought it from Summit Racing.
__________________
Thanks,
Rod
www.crazypetersons.com
TLCA # 9116
TTR #013
  #7
Old 10-15-2009, 09:26 AM
Newbie
Lil Blu Brute is on a distinguished road
Exclamation LSPV Problems
I've pulled my LSPV cleaned it and got it working properly. Seems most of the problem is right at the very bottom where the boot for the pin that contacts the cross bar is. Moisture builds up inside the boot and causes corrosion which locks the valve in either the compressed position (heavy load) or no load position. Carefully disassembling and cleaning the valve should work, but be forwarned if you're not mechanically inclined you could cause more damage and down your vehicle until you can purcase a new one or loose your brakes unexpectedly causing an accident. This is not a task for the beginer!
  #8
Old 10-16-2009, 01:25 PM
4Crawler's Avatar
Default
I finally pulled mine if anyone is looking for a working used one. I put in the rear discs and currently have no prop. valve installed but will be adding the Wilwood valve if needed.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
