dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's |
05-09-2007, 02:17 PM
| | Journeyman | | Join Date: Sep 2003 Location: Colorado
| | Exhaust leak - ghetto fix??
Hey,
So the previous owner of my 88 4runner (2.4L, manual) had replaced a small section of the exhaust down-tube (right where it bends) with a small section of flexible tube, supposedly made specifically for exhaust. Anyway it doesn't seal well and is causing an exhaust leak, which in turn, i think, is messing with my O2 sensor (and causing my truck to sound somewhat like a cessna...) I plan on putting a header and new exhaust on this thing but until I have money for that what's a ghetto way to seal this up? I was thinking something similar to jb weld but with a higher temp rating. Any ideas?
thanks,
andy
05-09-2007, 04:11 PM
| | Keyboard Implanted | | Join Date: Jun 2000 Location: Va. Beach, VA
put two clamps on it.
how's it affecting your O2? is your O2 further down the exhaust?
05-09-2007, 04:59 PM
It has a clamp on either end of the section. Do you mean to double these up? This is some kind of weird flexible tube made for exhaust repairs, but it doesn't look like it would compress very well if at all... Hence I want some kind of high temp sealant in there. As for the O2 sensor it's right in front of the cat, further downstream from the repair.
05-09-2007, 05:06 PM
Any thoughts on orange (high-temp) RTV??
05-09-2007, 06:15 PM
|  | Carpal \'Tunnel | | Join Date: Mar 2001 Location: Massachusetts
Never use RTV or any type of silicone stuff on the exhaust it stinks when it heats up!
For a good lasting ghetto fix call up some heating supply places and ask for furnace cement. They use it to seal the metal ducting back to the chimney after they clean it out. This stuff is designed to harden the more heat you apply to it! Buy a whole tub of it...apply generously around the leaking area and then pack it with your hands nice and tight. Next get a propane torch and start to indirectly heat the area and the cement will swell and harden...After it hardens some apply direct heat with the torch. When it looks good go ahead and start up the vehicle and let it idle for a few hours. Then it's ready to drive again. The next few days take it easy on the engine while the cement bakes in...When it's all said and done you will be able to get on the gas again and won't have to worry about leaks. If you get a blow out just apply more cement and repeat!
05-09-2007, 07:38 PM
Well, the permatex "copper" rtv is made specifically for sealing up exhaust... but I went with some "exhaust system joint and crack sealer" they had a autozone. Says it hardens with more heat too... we'll see what happens!
05-09-2007, 10:55 PM
| | Moderator | | Join Date: Sep 1999 Location: Black Hills of South Dakota
just go to an auto place. they make a kit for fixing that.
kind of like putting an old time cast on it. or header wrap.
or just pick up a new piece of the flex tube.
not much more then steel will last under that kind of heat.
05-10-2007, 01:54 PM
The copper permatex is for sealing gaskets and such not sealing your exhaust pipes. The stuff just isn't designed to take the heat and pressure unless it's sandwiched between two pieces as a gasket. You can use it on your exhaust and header gaskets etc but I don't recommend it...I just clean the surface alot and use new bolts and fresh gasket every time.
Let us know how it turns out with the stuff you got at A-Zone...If it's the same stuff it might be easier to buy it there instead of a heating supply shop. I needed bulk amounts back when I did mine though...I had a '84 Subaru Wagon and the "Y" pipe rusted out...Was like $600 for the pipe from the dealer and nobody would touch making a custom one back then...So I sealed the whole thing almost with that stuff and it got me a sticker and lasted a little over a year.
05-10-2007, 10:08 PM
|  | Apprentice | | Join Date: Oct 2006 Location: virginia usa
A split open beer can with both ends removed and two clamps.
__________________
P out the fire,call the dogs,and let's go home.
05-10-2007, 10:12 PM
| | Quote:
Originally Posted by scabbyota A split open beer can with both ends removed and two clamps. |
Your bringing back some memories now!
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 05:11 AM. |
