| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's |
03-03-2007, 08:23 AM
| | Carpal \'Tunnel | | | Join Date: Jun 2000 Location: Va. Beach, VA
| | Quote:
Originally Posted by 83GMCK2500 Hey, I'm a recent convert. Have a new 17" MBP 2.33 Core 2 Duo 2GB DDR2-667 160GB HD. | that's a hot machine!!!
I was eyin' those in the beginning, but then thought, you know, I really want a desktop. I don't like having a notebook as my primary. if they made the Macbook in the 15", I'd consider one of those and a very capable iMac.
Kev, do you have the P4 Extreme or Core2 Extreme?
03-03-2007, 09:30 AM
|  | Carpal \'Tunnel | | | Join Date: Oct 1999 Location: Newfoundland, Canada
| | What does this mean???
'ATI External Event Utility EXE Module stopped working and was closed'
__________________
-WayneM
1984 Toyota p/u
03-03-2007, 12:18 PM
|  | Administrator | | | Join Date: Mar 2001 Location: Massachusetts
| | ATI External Event Utility EXE Module. Another background task which gets installed when you install ATI display drivers. Under Windows NT4/2000/XP/2003 the service registers as the “ATI Hotkey Poller” and further investigation shows that it is related to the handling of various ATI Hotkeys which bring up specific ATI utilities. Not only is this facility useless to 99.99% of users, but there is also no documentation anywhere on those ATI hotkeys !! Additionally some of our more inquisitive users have been able to prove that ATI2EVXX can sometimes be an incredible resource hog using up to 85% of CPU utilization !! Older versions of this background task show up as ATIPOLAB in the Task List.
Recommendation: is to disable it on startup, if you can't find it on start-up you can try typing MSCONFIG into the text area of the start menu, then go to the startup tab and remove the check mark from the ATI External Event Utility. This will put the machine in selevtive startup mode and when you reboot you may get a screen advising this...simply take the check box out of the corner of that screen on your reboot, should say something like show this screen next you reboot. If it screws something up don't worry, just go back to msconfig and click normal startup and it's back to square one!
If you still can't find it in startup files try this: services.msc then look for ATI Hotkey Poller and set it's startup mode to DISABLED...that way the service won't launch on boot and you won't get the crash error anymore cause it isn't running.
An alternate thing to do is go directly to ATI's webpage and see if they have new drivers released for vista lately. Video drivers are updated constantly sometimes every month or so...sometimes every six months...depends on the issues.
Hope this helps
Kev
__________________ 1985 4Runner EFI 36x12.50 Swampers
Running ZUK installed 5.29's www.gearinstalls.com |
03-03-2007, 01:08 PM
| | Thanks Mudrunnerr88.....but all that sounds like a little over my head, lol. If you ever come across the ATI update link for Vista, post it here. I may attempt that, lol.
__________________
-WayneM
1984 Toyota p/u
03-03-2007, 01:16 PM
| | Quote:
Originally Posted by WayneM Thanks Mudrunnerr88.....but all that sounds like a little over my head, lol. If you ever come across the ATI update link for Vista, post it here. I may attempt that, lol.  | I need the make and model of your tower. If you can not find the model look on the front of the tower near the power button usually or on the back of the tower should be a sticker with the serial # and part #...or if you have the box still it should clearly state the model #. Also if the box says the model of the chipset or video card it helps...for example the latest intel chipset is i975. An example of the ATI card would be Radeon 9500 or something like that.
Does your monitor plug into the motherboard itself or is there an add-on video card where you plug the monitor in down near the bottom where the add-on blocking plates are?
03-03-2007, 01:27 PM
| | Scott, I got a P4 Extreme 3.4ghz running in my tower right now, and I have a Core 2 Duo sitting around waiting for another board (still selling my intel board socket LGA775 965 chipset)
03-03-2007, 02:57 PM
|  | Moderator | | | Join Date: Nov 2002 Location: State of Jefferson.
| | Here's what that looks like to the rest of us normal people.......
Module De service De l'Événement Externe EXE d'ATI. Une autre tâche de fond qui obtient a installé quand vous installez des conducteurs d'affichage d'ATI. Sous Windows NT4/2000/XP/2003 le service s'enregistre comme "ATI Hotkey Poller" et davantage de recherche prouve qu'on le lie à la manipulation de divers ATI Hotkeys ce qui évoquent des utilités spécifiques d'ATI. Est non seulement ce service inutile à 99.99% d'utilisateurs, mais il n'y a également aucune documentation n'importe où sur ces hotkeys d'ATI ! ! En plus certains de nos utilisateurs plus investigateurs ont pu montrer qu'ati2evxx peut parfois être un porc incroyable de ressource en utilisant jusqu'à 85% d'utilisation d'unité centrale de traitement ! ! Des versions plus anciennes de cette tâche de fond apparaissent comme ATIPOLAB dans la tâche List.
Recommendation : est le neutraliser sur le démarrage, si vous ne pouvez pas le trouver sur la mise en train que vous pouvez essayer dactylographier MSCONFIG dans le secteur des textes du menu de début, alors n'allez pas à l'étiquette de démarrage et n'enlevez pas la marque de contrôle de l'utilité externe d'événement d'ATI.
Ceci mettra la machine dans le mode de démarrage selevtive et quand vous rechargez vous pouvez obtenir un écran conseillant ceci... simplement prise la boîte de contrôle hors du coin de cet écran sur votre réinitialisation, devriez dire quelque chose comme l'exposition cet écran après vous réinitiali.
__________________
Jerod
"Hiking is just walking where it's ok to pee.....
Sometimes old people hike on accident....."
89 4Runner "The James Caird" Yeah, I named it.
03-03-2007, 04:32 PM
| | Does this help:
Acer Aspire T660
Video says built in graphics.
__________________
-WayneM
1984 Toyota p/u
03-03-2007, 05:11 PM
| | Quote:
Originally Posted by WayneM Does this help:
Acer Aspire T660
Video says built in graphics. | Here is ATI's link to the radeon x300 drivers (you have x200) but these drivers should support your machine. Catalyst® 7.2 Display Driver for Windows Vista (32 bit) if it says you can't d/l them you need to go back to the main page (it will re-direct you) then on the top right click drivers, then choose OS-Vista/Then RADEON/and finally scroll to find x300 model. The 38mb one should do you fine...the 80mb one is for multi language.
Something seems to be wrong with acer's server but here is the link that should be where you can find the manufactures drivers Support & Download if that doesn't work go directly to Global Acer.com and go from there.
Good luck!
03-03-2007, 06:30 PM
| | Okay, I did that download....everything worked, except it said that the 'uninstall' (option, I guess) was not sucessful. My screen is a little smaller. How do I readjust the screen now? Do I adjust the monitor settings, or do I do it through Display Settings?
My settings now are 1024x768, (0 degrees) Color: 32 Bpp.....whatever that means, lol.
__________________
-WayneM
1984 Toyota p/u
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 06:23 PM. |
