ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Toyota Forums > Toyota SUV's & Trucks
Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's
  #51
Old 03-21-2007, 10:06 PM
missouriman has a spectacular aura aboutmissouriman has a spectacular aura about
Default
sure, I just read everything that I could find. printed it all out.
bought the stuff and went to work.
still a ways off to see if it works well. depends on the weather also. I am working in the drive way.
cylinder is this one.
Surplus Center Item Detail
  #52
Old 03-22-2007, 09:45 PM
Default
well, pretty much finished up one side of the hydro mount.
fixed the radiator. shortened up the hydro mount bolts about 1/2 inch.
trying to figure out if I should make the tie rod mount the weak link.
or if I should just do it up the way I want and hope the cylinder doesnt break anything.
only had two hours to work on it today after work.
OK the cylinder puts out 5500 pounds force when supplied with 3000 psi of pressure.
the Toyota pump has no max listed anywhere. just to replace it if it is lower then 1250.
so I am going to guess that with the pressure that my old pump puts out I am looking at around 1500 to 1700 pounds of force.
I would sure think the arms and steering stops would take that.
with all the extra parts that I have I can replace anything that breaks.
so the other hand just says do it.
  #53
Old 03-23-2007, 11:43 AM
Default
Quote:
Originally Posted by mudrunner88 View Post
Interesting, can you post more about the hydro setup? That would be a cool project after I finally get crossover and a friend of mine just did his crossover and would like to know a little more...He will be signing up for the board soon just got his PC setup.
what specifics are you interested in...
there are many aw some write ups on this already.
like the trail gear set up.. but I am adding a cooler and modding the pump a bit. my cylinder is a bit larger, well the shaft is. the mounts that I am making are more beefy. my cylinder has the heim joint welded on. so the trail gear mount would not work. mine has to be horizontal to keep the fittings pointed backwards.
  #54
Old 03-23-2007, 03:25 PM
mudrunner88's Avatar
Administrator
mudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond repute
Default
How about some links to the write-ups and maybe a few photos as you go along...I just read something about take apart the stock box and drilling an extra hole in it to use that as the hydro supply for the actuator.
__________________
1985 4Runner EFI 36x12.50 Swampers
Running ZUK installed 5.29's www.gearinstalls.com
  #55
Old 03-23-2007, 03:29 PM
Myredyota's Avatar
Myredyota is on a distinguished road
Default
I just picked up a rear ubolt flip kit from Rockstomper.com.
That will give me something to play around with! I am going to add an extra leaf spring at the same time.
__________________
Carey
  #57
Old 03-25-2007, 10:11 PM
Default
well got the hydro together.
seems to work well. pulled the steering box back out to reseal some of the fittings, slow leak uggg. so one one of the factory fittings. A centering valve thing I used Teflon tape and some silicone gasket former. letting that dry over night.
had to make some adaptor plates for the bumper mount. it was really odd.
after tach welding it down. fabbing it up. it hit the fenders. so had to space it out about 1.5 inches further.
guess pink paint shrinks steel.. lol yes, it is pink.
then I need to come up with a front drive shaft.
turn the truck around and start on the rear springs. rear should be a one day deal... Just need to fab a dropped hard line bracket
weld on the new front spring mounts. cross brace the shackles that I made.
  #58
Old 03-25-2007, 11:04 PM
Administrator
Default
While your driving does the hydro affect feel like it's delayed after steering input?
Thanks for the links I will catch up on the reading tommorow, had a long day today.
__________________
  #59
Old 03-26-2007, 07:22 AM
Default
have not driven it yet, maybe this week.
see how the rear springs come out, that bolt by the gas tank is allways a pain. Plan is to saws all the bolt.
also hopeing the small leak in the steering box is now gone. I ground down the toyota stamp. Used tape on it. Tightened the heck out of it.
also I drilled out the restrictor on the pump to 13/64s I think. My plan book is out in the truck.
the cooler that I picked is the hayden 401.
  #60
Old 03-26-2007, 11:10 AM
Default
say can you copy my posts into a new thread called missouriman's wife's 85 build up?
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride.
