ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Toyota Forums > Toyota SUV's & Trucks
Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's
  #41
Old 03-11-2007, 01:10 PM
Kyron's Avatar
Carpal \'Tunnel
Kyron is an unknown quantity at this point
Default
This is my latest mod
__________________
*** "Make a little bird house in your soul" ***
  #42
Old 03-13-2007, 03:15 AM
Myredyota's Avatar
Myredyota is on a distinguished road
Talking I got a little tippy!
I got the body lift done and went out to do some Mall Crawling! I had to see if I had any rubbing Nadda!
Saturday I hope to get out on the trail for some real testing.
__________________
Carey
  #43
Old 03-13-2007, 06:04 AM
Rembrant's Avatar
Carpal \'Tunnel
Rembrant has a spectacular aura aboutRembrant has a spectacular aura about
Default
Kyron,
Nice work. Was that for clearance, or just for the view? All the salt they put on the roads here will do that to a Toyota in about 20 years....lol.
Carey,
Lookin' good, even at the mall....lol. Did you get new tires? They don't look like the ones I saw on your back last fall.
__________________
"Consider the daffodil. And while you're doing that, I'll be over here, looking through your stuff." -Jack Handy
  #44
Old 03-13-2007, 10:12 AM
Kyron's Avatar
Carpal \'Tunnel
Default
Quote:
Originally Posted by Rembrant View Post
Kyron,
Both
I even removed the front body mounts because the tires 38's sx were hitting the body mount. the axle is 2" forward even
I'll post up pictures of how the body is attached later (if it lasts)
I almost have a complete 3" 4crawler body lift ready to sell
__________________
  #45
Old 03-14-2007, 02:37 AM
Myredyota's Avatar
Default
Carey,
Yes sir! I got some Dunlop Mud Rovers. The work great on road in the snow. I can't wait to try them aired down to about 12-15 psi on the trail! This trip to Moab is running me some cash!
__________________
Carey
  #46
Old 03-19-2007, 10:51 PM
missouriman has a spectacular aura aboutmissouriman has a spectacular aura about
Default
fabbed up frame brace, front brace, made bumper, made shakles, tapped the steering box, installed the cross over. made and installed front diff protector.
have the front springs installed, cut up radiator support for the new steering box.
still need to mod the power steering pump.
make the rear spring front mounts.
make the ram mounts. going to try to make some kind of weak link, a shear pin deal.
make front drive line.
mount the bumper after I get the steering working.
wow fab work takes along time, clean grinding the steel, the welding, figuring out how to make the parts.
then I get to start on my truck.
  #47
Old 03-20-2007, 10:41 PM
Default
got steering box mounted up.
made some brackets for the hydro.
chained down the motor mounts.
re-enforced the steering stops and adjusted them so they hit on both sides at the same time.
picked up two more long U bolts and nuts... used the extra nuts to re-enforce the steering stops. they were just the right size.
found the mount on the radiator it self had broken loose so will need to solder that back up.
there is always something new to add to the fawking list...
should be awsome when done.
course next round will be the longs axles, and gears, 5.29's and a front locker when I put in the longs.
she already has marlin crawler's 4.7's in the transfer case.
  #48
Old 03-20-2007, 10:54 PM
mudrunner88's Avatar
Administrator
mudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond reputemudrunner88 has a reputation beyond repute
Default
I'm just itching to get my 5.29's and locker back from Zuk, then I need to scrape up some money for the front axle seal kit...
Umm if your bump stops are adjusted so both touch at the same time wouldn't that mean your driving straight all the time?
__________________
1985 4Runner EFI 36x12.50 Swampers
Running ZUK installed 5.29's www.gearinstalls.com
  #49
Old 03-21-2007, 07:34 AM
Default
lol, kind of sounded that way.
only my back steering stops would touch.
with the hydro I am putting in I wanted it pushing against two stops vs just one.
ps, a nut for a 9/16 th bolt slips right into the back side of the steering stops.
  #50
Old 03-21-2007, 07:56 AM
Administrator
Default
Interesting, can you post more about the hydro setup? That would be a cool project after I finally get crossover and a friend of mine just did his crossover and would like to know a little more...He will be signing up for the board soon just got his PC setup.
__________________
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride.
