ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Toyota Forums > Toyota SUV's & Trucks
Toyota SUV's & Trucks Discussion of Toyota Pickup Trucks and 4-Runner SUV's
Old 04-01-2006, 02:49 PM
denio1jct
Default Replacing Auto Hubs on 87 4Runner
I am going to replace my auto hubs with manual (Aisin) and I was quoted 1 hour labor / wheel... But the Tech made a comment about the hub bearings not lasting very long...
Is this a problem or should I be looking for another Tech..
Old 04-01-2006, 03:58 PM
JEFF_S's Avatar
JEFF_S is an unknown quantity at this point
Default Re: Replacing Auto Hubs on 87 4Runner
The hub bearings do not wear out like you were told. I have never had a problem with any of mine in over 18 years. What the guy might have meant were the wheel bearings. It would be a good time to repack the bearings and replace the brake pads if needed. Just swapping out the hubs though is rather easy. Do you have a set of hubs yet?
Jeff S.
Old 04-01-2006, 06:01 PM
2ndGenToyotaFan's Avatar
2ndGenToyotaFan is a glorious beacon of light2ndGenToyotaFan is a glorious beacon of light2ndGenToyotaFan is a glorious beacon of light2ndGenToyotaFan is a glorious beacon of light2ndGenToyotaFan is a glorious beacon of light2ndGenToyotaFan is a glorious beacon of light
One hour per wheel? I could probably swap them both in 10 minutes....... Is he going to go through the hubs and check them out? I hope so for that amount of labor. How many miles?
Read this, it'll give you an idea about what's involved.
http://www.4x4wire.com/toyota/tech/autohub/
Old 04-02-2006, 09:51 AM
denio1jct
I have 250,000 on it and I have the hubs.. I had the brakes and rotors replaced 18 months ago... about 15k on them..
If it is that easy to replace them maybe I should try it myself or look around for other places... I am the big 60 now and I try not to do that stuff anymore.. but $180 in labor is not chump change to anybody.. Thanks Guys: Jim
  #5
Old 04-02-2006, 02:56 PM
JEFF_S's Avatar
About the hardest part of doing the hubs are the cone washers. If you have done some before, you learn just how to do it, but the first timers usually struggle alittle. I use a brass punch and hit the ends of the studs with a hammer to jar them loose.
Good luck and if you decide to do it and have any problems, we can help you out.
Jeff S.
  #6
Old 04-02-2006, 03:29 PM
I like to loosen the nuts a little, then tap-a-tap-a on the out side edge of the hub with a hammer till the cone washer pops out. Works great.
I'd check for any play in the wheel bearings and make sure they are greased, if there is some play it's not too bad to tighten them up a little. But changing out the hubs is a piece of cake.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride.
