fj 40 timing I just bought 1974 FJ40 w/6cyl type f motor all stock. It runs bad, backfires,heats up, won't run more than 5 minutes and quits. When I go to check the timing I can't find any timing marks or pointer. I have a manual and it talks about an inspection cover, whicH I don't see. A mechanic said on the left side there was a little bead for timing. I don't see anything. I was going to try and time it by rotating dist. but the dist won't move. It has 1 bolt securing it in on the right hand side and like a "hose clamp" on the btm. when loosened the dist. hardly moves. On the left side of dist. it seems like there is a long slot but no bolt going thru it. I'm wondering if the dist. is in backwards?
but I don't understand no timing marks for 7 BTDC. ANy help? |
