ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Toyota Forums > Toyota Land Cruiser
Toyota Land Cruiser Discussion of all things, Cruiser
Old 10-28-1999, 07:13 PM
Default spring over lift?
I am interested in the spring over suspension lift. Any good sights? i need as much info as possible
is this crazy expensive to do?
looking for as much info as possible
thanks again guys
Old 10-28-1999, 07:24 PM
Default Re: spring over lift?
Also, whats up with this saginaw steering conversion... what does this run?
Old 10-28-1999, 08:11 PM
Hi Waylon, From reading your previous post,a spring over is probably not what you want. This will give you at least 5 1/2 to 6" of lift. You will also have to cut and turn the axle housings to correct the driveshaft angles. A spring over should only be done by a qualified welder familiar with this procedure. With a S/O you should also change the steering to a saginaw setup. This could run up to a grand alone (if you have someone do it for you) Also, when doing spring over axles, you usually do a shackle reversal. which CAN cost even more $$. The 2" suspension you were asking about is considered Mild, A spring over is Wild! How about an in between suspension. How about a 4" skyjacker kit w/revolver or anti-inversion shackles and Black Diamond shocks.
Old 10-28-1999, 08:44 PM
Check out the following write up on Off-Road.Com. Then come back and ask 50 more questions. We'll be glad to answer them.
http://www.off-road.com/tlc/tech/saginaw/
--Eric
  #5
Check out some of these sites. A spring over will cost more unless you can do it all yourself. Its not for the beginner, but after you start to live and breathe cruisers it'll become obvious. Anyway there is a lot of info to digest here, good luck!
Kurt
http://www.geocities.com/Baja/Dunes/6948/
http://www.csom.umn.edu/wwwpages/fac...im/tlcpage.htm
http://www.pirate4x4.com/index2.html
find the technical dept.
http://darkwing.uoregon.edu/~jrice/c...pringover.html
http://darkwing.uoregon.edu/~jrice/cruiser/Saginaw.html
http://darkwing.uoregon.edu/~jrice/cruiser/Shackle.html
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
