Will Welding of dana60 case crack it? - Off-Road Forums & Discussion Groups
Tools and Fabrication Forum for discussing the latest tools or fabrication methods for the Off-Road vehicle owner.
post #1 of (permalink) Old 02-24-2010, 04:18 AM Thread Starter
cal
Newbie
Will welding brackets on a dana60 diff housing crack it or distort it?
Since the houseing is cast.
I mean right on top of the houseing. I'm planing on making a angled swing arm type suspension with two tie rods on top center running out wards, then running 1/4 leafs.
|==O==|
..i../\..i...
cal is offline
post #2 of (permalink) Old 02-24-2010, 12:30 PM
Newbie
welding
Hello friend.here's what you need too do. completly clean it with super clean.steam clean that off then gring it down about 3 mill's.then grind a v DEEP.then pre-heat too 300 degree's.untill you touch it quick and the oil just burns off your finger.set the proper heat range on your machine and then stich weld.,peen it as you go.a little at a time. keep your material a the proper temperture.when done cove your work with something like alumimin foyal,and let it cool slowly.if you have trouble call me.Marty@ 209-293-1261.if you lived close I would do it for you for free OK?
moedidley is offline
post #3 of (permalink) Old 02-24-2010, 12:38 PM
Newbie
Quote:
Originally Posted by moedidley View Post
hello friend.here's what you need too do. Completly clean it with super clean.steam clean that off then gring it down about 3 mill's.then grind a v deep.then pre-heat too 300 degree's.untill you touch it quick and the oil just burns off your finger.set the proper heat range on your machine and then stich weld.,peen it as you go.a little at a time. Keep your material a the proper temperture.when done cove your work with something like alumimin foyal,and let it cool slowly.if you have trouble call me.marty@ 209-293-1261.if you lived close i would do it for you for free ok?
also most important-buy the proper rod or wire,stick work a bit better for cast steel.remember weld one inch then peen it good,thanks marty
post #4 of (permalink) Old 02-24-2010, 12:41 PM
Newbie
also most important-buy the proper rod or wire,stick works a bit better for cast steel.remember weld one inch then peen it good,thanks marty
I'll be right here if you need help,we have 9 differant welders to handle most jobs,good luck friend
post #5 of (permalink) Old 02-25-2010, 03:18 AM Thread Starter
cal
Newbie
thanks
Ok so i need to preheat an area as big as i can? 300~500 deg.
peen the weld after I'm done with each weld, then insulate.
Well four peices of metel 3/8" thick, 8 welds, all 2" long.
or a peice of chanel up side down ground to mach the curve of the diff then weld the brakets on top. two welds 4" long.
how would you do it?
I'm in salt lake sorry you cant help.
cal is offline
post #6 of (permalink) Old 02-25-2010, 04:03 AM Thread Starter
cal
Newbie
Nickle electrode and stick welding?
I think that a weld along the radius would be best right? a crack or stress would have to travel two directions.
cal is offline
Human Verification
