OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > General Off-Road Forums > Tools and Fabrication
Tools and Fabrication Forum for discussing the latest tools or fabrication methods for the Off-Road vehicle owner.
Old 02-18-2006, 07:18 PM
notofu
Default F@*&@#$ ford
I am Trying to install a 3 inch steering arm lift block into a 78 F-150 supercab. The steering arm has to be removed to add in the lift block. The steering arm does not want to come free, I'm looking for anyone that has done this before, or that knows someone that has, or anyone that has any usefull advice. Hope someone can help me before I blow my head off.post or email kurtmathers@gmail.com
Old 03-19-2006, 11:20 AM
stumblefoot's Avatar
Journeyman
stumblefoot is an unknown quantity at this point
Default Re: F@*&@#$ ford
I'm sure you've tried the BFH and heat? (Big Freakin' Hammer) A two arm puller has worked for me. try some wd40 from the top. If your replacing the arm, why not torch it off? Just be carefull not to get into the splines of the gearbox.
Old 05-18-2006, 10:22 PM
GTRider245's Avatar
GTRider245 is an unknown quantity at this point
By steering arm do you mean pitman arm? I wouldnt run a block there, but get another pitman arm for the length you need.
Old 05-19-2006, 09:51 AM
BigNorm's Avatar
BigNorm is an unknown quantity at this point
It sounds like an operator lack of mechanical knowledge issue rather than a brand issue.
  #5
Old 05-20-2006, 10:39 PM
GTRider245's Avatar
X2
  #6
Old 07-04-2006, 05:54 PM
krabysniper's Avatar
krabysniper is an unknown quantity at this point
Just my .02 on the subject as far as safety is concerned, NEVER USE HEAT OR HAMMERS ON ANY STEERING OR SUSSPENSION COMPONENTS it can cause failures that CAN cause loss of life. Use the PROPPER tools for any given susspension or steering component repairs or replacements. They do make the PROPPER tools for a reason.
I third the operator failure.
  #7
Old 10-02-2006, 05:32 PM
jdonahue
Krabysniper's post is correct. That being said you can easily remove your pitman arm with the following method.
Place a 4lb hammer on one side of the pitman arm where the sector shaft runs through it as a backup. Strike the exact opposite side of the pitman with another 4lb hammer, making sure to align hammers between blows. It shouldn't take too many hits to free it up. This is a junkyard method!
  #8
Old 10-26-2006, 11:54 AM
BAJA619's Avatar
Newbie
BAJA619 is an unknown quantity at this point
Try any autozone or pepboys style store for a pitman arm remover. They may rent them or have a tool useage program.
If you have to buy one, it might cost about $65 and would be totally worth it to have in your tool box.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
