ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > General Off-Road > Tire Tips, What Works Best
Tire Tips, What Works Best One of the most-talked-about subjects on our Boards; applies to all makes and models.
  #21
Old 09-27-2002, 05:05 PM
Steve83's Avatar
Steve83 is an unknown quantity at this point
Default 8.6
What was your original tire size? (Look on your VIN sticker in the door jamb.) Probably someone already messed with it. What's the lockout count now that you've used one? I suspect it's 4 or less. [img]images/graemlins/wink.gif[/img]
  #22
Old 09-27-2002, 08:46 PM
muddybronco's Avatar
muddybronco is an unknown quantity at this point
Default Re: 8.6
maybe you have an auto-ranging PSOM that sensed the new tires? [img]images/graemlins/grin.gif[/img] you must not be the first one to have put 33's on the truck [img]images/graemlins/wink.gif[/img]
also, you've been going WAY slower than your speedo reads, so you've probably been following the law and you didnt even know it [img]images/graemlins/laugh.gif[/img] [img]images/graemlins/blush.gif[/img]
  #23
Old 09-29-2002, 01:57 PM
Torvald
Default Re: 8.6
Ok the VIN is 1FMEU15N6RLA87608 The Axel code is H9 if that helps.
If the speedo has ben off, which it seems, that would explaine the 2 times I went flying by a cop going s#!+ and they never blinked [img]images/graemlins/smile.gif[/img]
Might this also explain the bad ping\knock I get at about 3000 rpm underload? I've been chaseing this problem since I got the truck. I've upgraded the ignition and opened up the air way some and moved the ping fron about 2600rpm up to 3000rpm witch moved out of normal driving range but under load or going up hil I lose power and it starts knocking prety hard.
  #24
Old 09-29-2002, 03:57 PM
Default Re: 8.6
dont get carried away Torvald, that sounds more like a timing problem [img]images/graemlins/wink.gif[/img]
  #25
Old 09-29-2002, 04:41 PM
Steve83's Avatar
Default Codes
I didn't want the VIN or axle code - I wanted the original tire size that's printed on that sticker. I'm also curious what your current lockout count is on the PSOM.
Your VIN only gives this info:
1FM - Ford Truck USA
E - 6000-7000 GVWR brakes
U15 - Bronco
N - 5.0L
6 - check digit
R - 1994 model
L - built at Wayne, MI plant
A87608 - S/N
That axle code only means that it's a limited slip (H) with 3.55 (9) ratio & 3800lb capacity.
  #26
Old 10-30-2002, 10:46 AM
Torvald
Default Re: Codes
Ok, I need to read ALL the directions first. The problem was my mis reading the 806E and the setting. New issue I can't seem to get the PSOM to go into set mode. I have found the wire and ground it out to both the dash ground and a interior light ground both of which tested as good grouns with a meter but the PSOM will not "flash" and let me chang the settings per the directions in this thread. Any ideas?
  #27
Old 10-30-2002, 11:41 PM
Steve83's Avatar
Default Flashing
It probably won't flash until you press the Select button the first time. [img]images/graemlins/wink.gif[/img] [img]images/graemlins/cool.gif[/img]
So what's your original tire size??? [img]images/graemlins/confused.gif[/img]
  #28
Old 10-31-2002, 02:05 PM
Torvald
Default Re: Flashing
Orignal size was 265/75R15. I'll try it again tonight and see if I can get it to work. Hopping up my 69 Firebird I know all this computer controlled stuff makes me nuts.
  #29
Old 10-31-2002, 04:05 PM
Steve83's Avatar
Default Nuts
You think playing with the plastic gears inside the t-case would be relaxing?????? [img]images/graemlins/confused.gif[/img] [img]images/graemlins/frown.gif[/img] [img]images/graemlins/tongue.gif[/img] I went to a LOT of trouble to switch to the PSOM because it's SOOOOOOOOOOOO much easier IMO! [img]images/graemlins/cool.gif[/img] [img]images/graemlins/smile.gif[/img] [img]images/graemlins/grin.gif[/img] [img]images/graemlins/wink.gif[/img] And I don't regret it!
  #30
Old 10-31-2002, 04:16 PM
reptillikus's Avatar
Pooh-Bah
reptillikus is an unknown quantity at this point
Default Re: Nuts?
I dunno steve, i dont think its that bad to do......but then, i only had to change the small gear, so it took me under 5 minutes to do
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
