Racer Tech Polaris RZR XP4 900 Dual Rate Replacement Spring Kit - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Supporting Vendors > SXS Headquarters
SXS Headquarters UTV Parts & Accessories
Old 12-03-2013, 03:35 AM
Supporting Vendor
SXSHQ is on a distinguished road
Default Racer Tech Polaris RZR XP4 900 Dual Rate Replacement Spring Kit
Racer Tech introduces an amazing blend of ride quality and performance for the 4 seat RZR XP4 900. Our Dynamic Inertia Spring System (D.I.S.S.) has been proven for years in other replacement spring kits we sell and seems to get better and better for each model that comes out.
This kit is a complete set of dual rate springs for the front and rear which are 2.5” I.D. front and 3.0" I.D. rear. This makes this kit universal to all aftermarket 2.0" front / 2.5" rear or equivalent shocks so if you ever decide to upgrade to aftermarket shocks you don’t have to buy shocks with springs. You can take your Racer Tech springs with you! Good thing too because this spring kit is constantly being proven to be a better setup than even the aftermarket shock companies can provide with their shocks.
This kit includes adapter rings for the front shocks which convert the OEM upper and lower spring retainers from a 3.0” ID set up to the 2.5” springs that come in this kit. The rear springs do not require adapters. The kit also includes Racer Tech’s CNC machined Delrin spring spacers. These are designed to slide up and down the body of the shock straight and true for a long time due to their precision design and high quality American material.
Rates:
Medium - This rate is perfect for all dune and trail use. We've found this option works for almost everyone. The ride height should be about the same as stock and the ride quality when driving slow is very similar but a little firmer. The bottoming and bucking is greatly reduced and the handling is vastly improved when driving with two or 4 people. This rate will also support some extra cargo and accessories.
Heavy - This rate is only needed for machines carrying LOTS of extra weight. These are meant for desert race cars and very loaded down machines with 4 full size passengers all the time or a bunch of extra accessories, gear, spare tire, gas cans, etc. This kit is designed to maintain ride height with a full load. It may sit a little taller without a large load but the ride will be firm.
Note: The rear spring protectors can be retained with this kit.
This kit is 100% MADE IN THE U.S.A. and we at RT are VERY proud of this!
This kit fits all year RZR XP4 900 4 seat models. This does not work for XP 2 seat models! However, these WILL fit the Jagged X model.
Kit includes (8) springs, (4) adapter rings and (2) front spring spacers. *NOTE* - OEM rear spacers are re-used. The pics are wrong.
All springs come with silver powdercoat.
Guarantee
"It's hard to say what's the best when you've only tried one. At Racer Tech we believe we have the best spring replacement kit in the world and are willing to put our money where our mouth is. If you have a competitor’s spring kit and want to try ours, buy it. If you don't feel our springs are better than what you have you can send them back for a 100% refund."
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
