| Suzuki GEO All Discussion of all things, Suzuki and GEO |
What's the best way to remove surface rust on my American Racing chrome wheels?? There is not a lot of it... and it's strictly surface... However, I don't want any!! LeeClark 1988 (early) Suzuki Samurai "Life is what you make it... make it worthwhile" |
| Sponsored Links | ||
Advertisement | ||
Well, if it's chrome and there is rust it is probably not surface. Anyway, you can use navel jelly or Bon Ame to remove the rust that has progressed over the chrome from the material under the chrome. I preferr Bon Ame because it is cheaper, works as good or better than navel jelly and you can use it on many other things. Bon Ame is generally available at your grocery store in the cleanser dept. I have used Bon Ame on fiber glass, polished stainless steel, and gel coat with no problem, so it won't stratch your chrome. -Farther |
Thanks Farther for the info... It's appreciated!! LeeClark 1988 (early) Suzuki Samurai "Life is what you make it... make it worthwhile" |
Does that stuff work on aluminum? I'm LOCKED! Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r |
#5
a brillo pad works better then naval jelly or bon ami....i clean mine with that every summer to get rid of the rust from the winter....works like a charm every time ICQ# 18103928 AOL IM: Freebird01JM 83 F250 4x4 (For Sale!!) 66 Bronco 87 Samurai (soon!) Feel free to message me anytime!! |
#6
triple 0 "000" Steel Wool works wonderful to shine up the chrome and get rid of the rust. you will want to seal it afterwards with something? to keep the rust from coming back. I used to just keep using the steel wool on my chromed up motor cycle. worked great and does not scratch chrome. Rich_D If you don't do anything, How do you know when you are done? |
#7
worked at my family biz . for years(chrome shop) ...if you hit chrome with any kind of abrasize you are scraching the surface. the surface of the plateing is less than a millimeter...way less. "chrome" is really nickel plateing that has been treated with high DC currant and chromatic acid .that treatment is what gives the nickel the deep blue and the hardness to resist scraching . if you use an abrasive on it ... it will remove the hardend outside layer of "chrome "and leave the untreated layer of nickel underneth.nickel can look very brite ...but it tarnishes very quickly...and is very soft. all i can say is NEVER DULL.NEVER DULL is a non-abrasive metal cleaner.it works on just about any thing ,form silver to brass to chrome.it will not damage surfaces. it will remove the rust,it will pertect the metal ...but this is just the symptom of the problem. the sun/ salt/road crap,have penitrated the plating "seal" the chrome treatment has been compramised.and it will continue to rust. never dull will help alot without making the problem worse ...as well as have many non auto related uses. but,if it bothers you alot ,i would look in to takeing them to a shop to be refinish,or look into buying new rims . i just wanted to help you out not bum you out . i hope this helps . p.s. the fact that i can't spell to save my life does not mean i don't know what i am talking about .(well in this case any way) zukikid wow ...it still fits out the garage !!!! |
#8
I always used steel wool and paste wax.. kills 2 bird with one stone, cleans off the rust and seals the surface. I did my ARE Tailgunners last year and they still only lasted about a year before the rust started creeping out again. How come chrome wheels rust anyway?? 93 Tracker, ProComp, Calmini, 31's, Thorley, K&N, etc..., aka the donor. Looking for a donee.. http://www.geocities.com/mini4x ICQ: 12438978 AIM: Mini4x |
#9
Mine are starting too rust as well.....thats why I'm going to ditch them as soon as I can and going black beadlocks! |
| Sponsored Links | |
Advertisement | |
« Previous Thread
Next Thread »
| Thread Tools | |
| Display Modes | |
