dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Suzuki GEO All Discussion of all things, Suzuki and GEO |
08-05-2009, 07:33 PM
| | Newbie | | Join Date: May 2009 Location: CO
| | Lifting Sammy i have some Questions plz answer
Hey all im doing a SPOA lift on my 91 samurai and putting 33" tires on it. One question is 12.5 wide to wide for the sammy? Do i need spacers? Another question is how much of a lift would my SPOA give me? I was guessing 4-5 inches and enough to fit the 33" tires yes? Thanks ahead of time for answering my QQs
08-06-2009, 04:25 PM
|  | Keyboard Implanted | | Join Date: Mar 2000 Location: Northern Catskill Mountains, NY
If you add a 2" body lift, on a 5.5" SPOA, you'll fit 33"s if you bumpstop it correctly. Also, 2" backspaced rims are needed for 12.50" wide tires.
__________________ Yankee Tim |
08-27-2009, 04:37 PM
| | Veteran | | Join Date: Jul 2002 Location: San Diego, CA
Ya what he said...OR... go with a 6" lift and forget the body lift altogether. Keep in mind that once you go into the 33" arena you are bound to break something depending on driving style and what kinda terrain. I have been running 31's for 8 years now and am very pleased with performance and dependability.... as long as I stay off the REALLY BIG rocks. Been there and my belly scrapes a whole lot more than the JP guys with 35+... but I can keep up with them.
__________________ billybob_CA |
09-09-2009, 01:55 PM
| | Veteran | | Join Date: Jul 2002 Location: Wasilla Alaska
I did a Spring over and put Wagoneer springs on my rig.
I just rub a little at full compression and full lock using 33 x 14.5 Boggers.
Had to re-work my front rims for more back spacing--I was hitting the springs at full lock.
If I were to start over, I would Not do a spring over.---I would trim the fenders and wheel wells. Keep the CG down. Just my opinion based on 8 years of spring wrap.
__________________
Cust Waggy SPOA,Pan Hard,bumpers
Warn M8000 on hitch
OBA
WeldedRear ARB Front
Calmini 4.16 t-case
Hybrid Diff 5.12
EXO Cage
09-09-2009, 02:05 PM
| | Quote:
Originally Posted by AkDale I did a Spring over and put Wagoneer springs on my rig.
I just rub a little at full compression and full lock using 33 x 14.5 Boggers. | bumpstops. Proper bump stopping prevents rub on compression. Rub during turning means 1 of two thing. Improper backspacing (for size of tire) or just too wide a tire.
09-09-2009, 02:18 PM
Very true Yankee Tim.
When I put the wagoneer springs on, I should have inboarded the springs.
I centered them where the originals were, which helped to create the spring rub, in addition to the wider taller tires. The springs are almost 1" wider than the zuke springs which moved them outboard by 1/2 inch.
Just was not thinking.
Other than that, this build has worked great. I have only been through 2 Barfields---And that was after I put the ARB Locker in the front.
__________________
Warn M8000 on hitch
OBA
Calmini 4.16 t-case
Hybrid Diff 5.12
EXO Cage
10-04-2009, 11:06 AM
|  | Novice | | Join Date: Apr 2008 Location: Milaca, Minnesota
I agree with everything allrdy posted here even with 10.5 tires I rub alittle at full turn. Rims with backspacing is the key here, and I would also ditch the body lift idea and just do the extra lift if needed.
10-05-2009, 08:57 PM
|  | Keyboard Implanted | | Join Date: Feb 2001 Location: Kansas City, MO
| | my 2 cents...
Going to 6 inches of suspension lift also makes for driveline problems.
Check this classic article on samurai lifts from an old pro: Ack's FAQ: Your 4X4 Portal To All Things Suzuki/Geo
Something to consider...
__________________
Ack Ack's FAQ
Over 550 searchable links to Suzuki modding and maintenence info!
'88 "SJ-416 Samurai"
'96 Tracker
'02 Tracker ZR2
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 04:11 PM. |
