| Suzuki GEO All Discussion of all things, Suzuki and GEO |
hi to all.....new to this board..... need any suggestions for carb change possibilities on 89 suzuki sammy. hi po stuff like webbers not needed..as it is just a driver and dont need to worry about smog laws....but must get rid of that stock carb nightmare..... thanks in advance chief rock |
| Sponsored Links | ||
Advertisement | ||
| Quote:
For articles on each, do a search for carburetor at acks FAQ. The link is in my signature below.
__________________ Ack Ack's FAQ nearly 837 searchable links to Suzuki/Geo modding and maintenence info - including the Tracker FSM Project! '88 "SJ-416 Samurai" '11 Ford Transit Connect XLT |
ok.....thanks a bunch....will check it out. all info will be appreciated since iam new to the zook nation.. .i think evently i will swap engines ,,,,,looks like theres room for some otherbrand of small eng and auto....and the front drive shaft doesnt look like a problem. chief rock |
CV carb. No doubt that right now it is the best thing going for carb swaps on Samurais. Go HERE and scroll down to the My-Side Sidedraft system. I fabbed my own, but I have the mad-scientist-booty-fab-skills-o-death. The price of the kit and a good used carb will be about the same , or maybe less than a Weber. I replaced a Weber w/ a CV. Matt aka Lizooki on the Zu |
#5
what about a carb spacer. anyone know about those and how it will help the stock carb fiasco?
#6
| Quote:
btw- If you have a good working stock carb...leave it alone! I you have the slight off idle stumble, get the venturi tube fix. NOTHING works as well as the stock carb on a sami ( or stock EFI ). But when it goes bad Matt |
#7
| Quote:
#8
i really appreciate all the info....... i build 'stuff''.....and agree that in my case the stock carb running great is the best way to go. however in my sammy on the road it is the scaryist .....will not take more that 1/4 throttle on the front barrel....50 MPH....with 80 mph traffic breating down your neck....wow... i have decided to0 install the toyota 1200 [74-75] carb......as published in acksfacts....bought it on ebay...will be delivered next week. searched local junk yards ...no luck. reasoning..... fits manifold without a big problem....fits under hood, and can use stock air cleaner.... AND...it seems about as simple as they get......i will have to fab all the brackets etc.......but overall..pretty simple. i feel this car is suffering from some sensors gone south.....iam from tx.....bought it in colorado 8 months ago to tow behind my RV. cherry, 52000 mi and absolutely no rust...$1400..... had looked SERIOUSLY for one for 12 months. had a ..check eng light on......drove it to 12000 ft and all over the rocky mountains....starts , idles and runs perfect....but will not rev. i want the simplicist rig i can build for where i go in strange terrority. so iam willing to rewire the whole car if i have to to get rid of that ![]() ![]() ![]() computer. after reading the acksfacs ariticle , i was convinced. but, how in the H**8 can i be so lucky to find that carb. junk yards are smashing everything past 1990....and the gov . wants every thing except new cars off the road. all the hot rod orgs. i belong too have been fighting this for 25 years. somewhere down the road modified stuff like we all love will only be trailered to some kind of event. THANKS ......open to you comments. will let you know the results. chief rock. |
#9
received toyota carb from online carb dealer in cal i bought on ebay..... looks absolutely fabulous and new. has two hard to get base gaskets and fuel inlet fitting. my final analysis will be after installation and test driving.....a new 2'' exhaust, no cat and this carb should make this oversized sewing machine motor rev. to its potential. chief rock |
#10
carb fit perfect....redid base spacer as per article, made my own gaskets. the air cleaner is a different story.....this a 74/75 toyota carb ...different than article. the underside took a lot of massaging to clear the linkages .... with hammer. plus , a new more flexable hose because the air cleaner bonnet is distorted from hammer blows....made new thicker gasket....to allow A/C to square itself and seal when bolted down. looks good. carb throttle cable bracket..... this carb is NOT compatable to the samuri cable end. i removed the cable attachment bracket from the sammy carb , cut some off of it , drilled some holes in it and the 74 carb bracket and attached it . this is the sammy carb part that the cable winds 1/4 away around it. works good .... throttle cable hold down bracket .. fabed from metal , and bolted to the two bolts on top of the thermostat housing, running to the rear parallel to the valvecover . a vertical piece welded to attached the throttle cable and man choke cable hold down bracket, which i removed from an old 3310 holley. am going to strip the harness to pull out all the carb plugs and route them under the dash, where they will be unseen. it looks like a nice setup.....however ,it must be very docile on off idle creeping as well as being able to rev on the hiway. we will see....no going back now. more info later..wish i could put up pics. chief rock |
| Sponsored Links | |
Advertisement | |
« Previous Thread
Next Thread »
| Thread Tools | |
| Display Modes | |
