OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Suzuki GEO All
Old 02-19-2007, 11:04 AM
Stranger
thespecialistkc is an unknown quantity at this point
Default Emissions suggestions....
SO here we go.... '86 Sammy, engine is stock except for chevy alt., vent tube and custom snorkle with all vent lines plumbed into it. 2" exhaust with a fairly fresh cat. (4 years old). Went to get emissions done yesterday, and I failed. I don't just mean failed a little, it bombed. I'm usually pretty smug when the operator exclaims "that thing will never pass!" as it always has in the past, by a large margin. Not this time. High CO on the low speed test. Mechanic says "looks like a bad O2 sensor to me". Sooo, off to the store for an O2 sensor and another set of plugs (since I hadn't changed them in years). Gap on old plugs was almost .065!!!!! Gapped new plugs at .031 and put in new O2 sensor. Retest this morning. Worse results this time around!!! CO on the high speed test climbed from a passing 02.87 to a failing 06.21, low speed decreased from a failing 06.23 to a stil failing 05.46. What the heck?? Mechanic sez.. "Looks like she's running rich to me". Really? Ya think so?
So, I'm looking for advice. My current course of action is this: Check all vaccuum hoses for leaks, check the EGR valve, check the timing, inspect the carb. for any obvious problems (seems like I remember you can't manually adjust the mixture, right?), and beyond that... I dunno....
Suggestions?
THX, KC
Old 02-19-2007, 08:25 PM
billybob is an unknown quantity at this point
Default Re: Emissions suggestions....
Could it be that the snorkle is causing her to run rich??
Just a thot
Old 02-27-2007, 10:25 AM
Carpal \'Tunnel
wildweasel is an unknown quantity at this point
Default
No adjusting the stock carb, disconnect the snorkle, if it is is under 2" id,
set the timing to 12Deg btdc (retarding it lowers the readings)
Fix the EGR. if it is a 1.3 the passege is clogged from the exhuast manafold to the other side of the hear. an old speedo cable in a drill chuck can clean it.
__________________
Glenn
1996 Suzuki X-90
http://www.cs.umass.edu/~glenn/personal.html
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
