PTO for Samurai T-Case - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 10-22-2004, 10:17 PM
AkDale is an unknown quantity at this point
Default PTO for Samurai T-Case
I know that the t-case has an option of a PTO.
Anyone know the details? Where to find out?
Where to buy the kit?
Thanks
Old 10-22-2004, 10:28 PM
ka4yqi is an unknown quantity at this point
Default Re: PTO for Samurai T-Case
Dont know here either, Dale, but I like to have one myself. If you get any info, pass it on.
Steve
Old 10-23-2004, 11:17 AM
szki272's Avatar
Pooh-Bah
szki272 is on a distinguished road
might try here www.amphijeep.biz never have herd of anyone having a pto on theirs
another option would be to run a sidekick tranny and t case with a samurai case behind it
Old 10-23-2004, 11:48 AM
I read somewhere that someone was using a pto for a fire pump---Either in New Zeland or Australia.
Amphijeep----Hmmmm---
That is exactly what I am thinking I am going to do with my 6x6 when I start the project this winter.---Which is why I am looking for the PTO--To run the prop.
  #5
Old 10-23-2004, 03:44 PM
szki272's Avatar
Pooh-Bah
I know they exist just never known of anyone having one the link I posted is to a place that uses the pto to drive the prop
by the way the pto mounts to the back of the t case at the rear of the input shaft there is 4 bolt holes and a metal cap there the shifter I think would come up thru the floor where there is that round inpression in the floor
the problem is I figure the pto uses a special input shaft meaning it will only work with the stock t case gears
  #6
Old 10-23-2004, 04:45 PM
88.5 Samurai's Avatar
88.5 Samurai is an unknown quantity at this point
Look at the sixth pic on this page-> http://moose.ca/~slowzuki/slowzuki/t...ases/index.htm
  #7
Old 10-23-2004, 08:05 PM
xfaktor is an unknown quantity at this point
that look like half of a samy t-case..
the input part is different.
getting more and more [img]images/graemlins/confused.gif[/img]
  #8
Old 11-02-2004, 11:45 AM
szki272's Avatar
Pooh-Bah
I emailed them about the pto they use for their boat hybrid this is what I got back from them.
AMPHIBIOUS CARS LTD
Littlehampton Marina tel 01903 721139
Littlehampton info@amphijeep.biz
West Sussex amphijeep.biz
BN17 5DS
ENGLAND
PTO for Suzuki SJ410/413/419 Samurai/Sierra/Gypsy/Potohar/Katana
Manufactured in Japan/Spain/India/Pakistan
We have been using our own manufactured PTO on the Dutton/Amphijeep range of amphibious cars since 2000; it is designed to transmit the full 65 bhp @ 5000 rpm
The conversion consists of extending the transfer box input shaft with drive shaft grade steel and drilling out the transfer box end casing to 23mm dia. There are 4 off M8 pre-tapped holes around this end casing suitable for attaching brackets etc
DIMENSIONS: -
Shaft 22mm dia x 65mm long from rear face of bearing to spigot
Keyway 6mm wide x 3mm deep x 23mm long
Spigot 15mm dia x 25mm long, machined finish to run in bush. This can be cut off if not required
The standard Suzuki rear end bearing must be the type fitted with double rubber oil seals (2RS), if your bearing is a plain ball bearing without seals it must be replaced.
If you are interested in a drive shaft/dog clutch assembly as per our amphibious set up please ask
ORDER: -
Modify input shaft and supply 6mm key 78.00
2RS double seal rear end bearing with 2 rubber oil seals 14.80
Carriage UK 8.50
UK sales add 17.5% vat
  #9
Old 11-02-2004, 02:41 PM
mudlite is an unknown quantity at this point
Question is, what would you do with it?
  #10
Old 11-02-2004, 03:23 PM
szki272's Avatar
Pooh-Bah
Fire pump as said above or maybe a small pto winch, hydrolic pump, runnung a second t case for a 6x6, and I am sure others can come up with other things.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
