??Will Gasoline eat PVC Pipe?? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 01-15-2004, 04:44 PM
billduck is an unknown quantity at this point
Default ??Will Gasoline eat PVC Pipe??
Does any one know if Gasoline will break PVC pipe.
What i am intending to do is to use if for a gas tank filler tube on my samuria's new gas tank.. i need to install a few straight peices as well as and elbow or two.. I kinda figured that gas will eat the glue used to assemble PVC pipe, so a simple two part epoxy that is gas resisitant will do. Also would there be any advantage's to useing polyurethane pipe??
Thanks
Old 01-15-2004, 05:46 PM
Carpal \'Tunnel
Location: Kalifornia, Don\'t blame me for the insanity, I\'m a native and were in the minority!
outlawmws is an unknown quantity at this point
Default Re: ??Will Gasoline eat PVC Pipe??
I'm pretty sure it won't hold up, while I don't have access to a reference to verify that, but google provided
This: PVC hose which has mild resistance to gas, is intended for oils and mild chemicals...
Bottom line: not recommended.
Old 01-15-2004, 05:55 PM
zooky's Avatar
zooky is an unknown quantity at this point
how about exhaust pipe?
Old 01-15-2004, 06:05 PM
87zuke's Avatar
87zuke is an unknown quantity at this point
If the PVC doesn't do it there may be some type of plastic pipe that will work.Some gas tanks are made of plastic as well as gas cans and even the storage tanks in new gas stations I believe are plastic. Jim
  #5
Old 01-15-2004, 06:23 PM
se thats the thing.. i am trying to figure out what jerry can's are made of..i thought it was polyurethane.. but i am not sure.. Exhaust tubing will work but i cannot easily (and cheeply) get the proper bends. when they bend exhaust a 9 degree is too long.. pvc and poly pipes have nice little elbows!!
  #6
Old 01-15-2004, 06:31 PM
Ok. i just found the WEDCO (gas can manufacture) website and they stated that the cans are made from Polyurethane.. so that should mean that i can use polyurethant pipe and elbows (a bit more expensive then PVC) Hopefully that would work.. any opinions.....
  #7
Old 01-16-2004, 09:04 AM
RgdL's Avatar
RgdL is an unknown quantity at this point
You should be OK with polyethylene Bill. You might want to use a short piece of rubber hose at the tank connection to decrease vibration and prevent the whole works from coming apart. After all, it is bouncy, flexy trail rig isn't it? [img]images/graemlins/grin.gif[/img]
  #8
Old 01-16-2004, 09:15 AM
Mini4x's Avatar
Mini4x is an unknown quantity at this point
My calmimi body lift came with and extension that I am sure was exhaust pipe..
  #9
Old 01-16-2004, 09:24 AM
n0lan is an unknown quantity at this point
try to find something made of HDPE {High Density Poly Ethylene}. Instead of using pipe, maybe look into hoses that are HDPE so you don't have to worry about bending pipes or using elbows etc..... just my .02
  #10
Old 01-16-2004, 02:16 PM
MUDFKR's Avatar
MUDFKR is an unknown quantity at this point
P.V.C is a no go with petrol, polyethylene is petrol resistant but cannot be glued for your corners so you must
weld it and on thin tube this will be reasonably hard not to get pin holes in your welds.Also when you hose clamp it to the filler / tank it won't seal any where near as good as the rubber hose as its more ridged than rubber.
As for using hose check what it is and weather it breaks down over time with petrol, a lot of hoses contain extra chemicals over the primary plastic to make them flexible
which can cause break down in time.
I'd be using exhaust tubing and weld in bends to suit if you can over any of the above.
Shane
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
