Engine Temp Stays Cold - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 12-03-2003, 08:39 AM
Lil_Mudder is an unknown quantity at this point
Default Engine Temp Stays Cold
I live Canada (Ottawa) and am having an interesting issue with the samurai. The weather now is about -7C and the engine will not warm up. I have the highest temp Thermostat in it with half the radiator covered with cardboard and it still sits just under a quarter after driving it around for an hour [img]images/graemlins/cussing.gif[/img]. I was wondering if there is anything I could try other than putting in a larger piece of cardboard. Should I change the mixture level of the anti-freeze?
Old 12-03-2003, 09:36 AM
mygreenihc is an unknown quantity at this point
Default Re: Engine Temp Stays Cold
Move south about 2000 miles. [img]images/graemlins/smile.gif[/img]
Old 12-03-2003, 09:45 AM
Buddy... Telm me about it!
Old 12-03-2003, 09:53 AM
Carpal \'Tunnel
Location: Kalifornia, Don\'t blame me for the insanity, I\'m a native and were in the minority!
outlawmws is an unknown quantity at this point
Use the bigger cardboard, (I like to use carpet as it is less likely to damage the core and fins)
Use the antifreeze as the directions tell you for your minimum temps. a forzen block is all too often a
broken block.
  #5
Old 12-03-2003, 10:00 AM
I didn't know that there was different mixtures for diffrent temps. I'll take a look at the Chilton tonight and see what it tells me.
Thanks
[img]images/graemlins/grin.gif[/img]
  #6
Old 12-03-2003, 10:20 AM
szki272's Avatar
Pooh-Bah
szki272 is on a distinguished road
might try pulling your manual fan and going with a small electric to save on cost you could pull the manual drive it around some and see if it will warm up if it does then get the electric if it doesnt then it must be somthing else are you shure the motor isnt heating up and it isnt just the guage?
  #7
Old 12-03-2003, 10:32 PM
zuk88's Avatar
zuk88 is an unknown quantity at this point
After installing a new radiator,water pump,and thermo my zuk rode just over the 1/4 mark in 90 degree heat at rockcrawling speed. Try covering the whole radiator and see what happens. I don't think running your engine cold is bad, unless your heater is blowin cold too.
  #8
Old 12-04-2003, 02:55 AM
Marcin
I would say that 1/4 of the temp scale is normal temp of my samurai. It was normal on orginal motor, and now it's normal on my 16V one. I have clean radiator, good water pump &amp; electrical fan. The fan had never started to work on a black road. It works only when I'm offroading.
Now I have outside temperature about -3/-5 and half of rad is coverd. Motor temp is 1/4 scale.
  #9
Old 12-07-2003, 12:19 AM
wolfie
THe different mixtures are mainly just jell points for freezing it doesn,t affect engine heat. I like using
clorplast in front of the rad it looks like cardboard cheap or free. Election signs are made of it quite often.Hope this helps.Is the clutch fan stuck on??
1988.5 sami
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
