Trick to align and center steering wheel - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Suzuki > Suzuki GEO All
Old 07-19-2003, 09:47 PM
moof
Default Trick to align and center steering wheel
After installing the Calmini 3" lift in the X-90, I was able to "ballpark" the toe-in by measuring the difference between the front and rear of the tires. (the new tires had a line painted on them.)
Centering the steering wheel was a "trial and error" process. It was difficult to know when the wheels were pointed "exactly" straight ahead. Lengthen one tie rod, shorten the other. Test ride then lenghten/shorten again.
An "old timer" happened to stop by and told me this trick. Run a string around the vehicle at the center of the hubs. Center the steering wheel, then observe the string where it meets the sidewalls of the front tires. Adjust the tie-rods until the string lies flat against all four sidewalls of the front tires. The steering wheel will be centered and the toe will be close to zero.
Tried it and it worked well.
Old 07-19-2003, 10:13 PM
scott400f
Default Re: Trick to align and center steering wheel
It's quite simple once you feel the wheels are aligned remove the horn cap pull the nut off the shaft pull the wheel and stick it back on in the new position!!
Scott [img]images/graemlins/40BEER.gif[/img]
Old 07-19-2003, 10:38 PM
moof
That aligns the steering wheel, but does nothing to center the steering box.
Old 07-20-2003, 10:10 AM
szki272's Avatar
Pooh-Bah
szki272 is on a distinguished road
my samurai doesnt have an ajuster in the linkage from the steering box to the tire only from one tire to the other removing and recentering the steering wheel is the only way with out cutting the linkage or buying an ajustable one
  #5
Old 07-20-2003, 10:49 AM
Mini4x's Avatar
Mini4x is an unknown quantity at this point
Well the right way to align the Trackick woul dbe to atart with the wheel centered.. both sides are adjustable..
the Sammy only has one adjuster (toe setting) and you have to align the whel by removing it.
  #6
Old 07-20-2003, 11:26 AM
Journeyman
climberdood is an unknown quantity at this point
What am i missing? Center the gearbox with the pitman arm. Center the steering wheel while the pitman arm is off.
  #7
Old 07-20-2003, 11:48 AM
DougO's Avatar
Pooh-Bah
DougO is an unknown quantity at this point
is to put it on an alignment rack
[/ QUOTE ] you have more choices, have an adjustable drag link made is the one that makes the most sence. The breeze and sky mfg Zlink are adjustable.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
