ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Suzuki GEO All
Old 07-06-2003, 10:48 PM
TRAILMASTERC
Default New to Board have questions?? HELP!!
I have done a search and can't find answers... I want to know if anyone has an inexpensive way to lower the gear ratio other than replacing the ring/pinion? I also would like to know if anyone has replaced there stock altinator with something other than a factory one. If so what kind and how much does it cost,where do I get one?
Thanks for any help!!!
I am also planning a trip to Uwharrie 7-12-03 Saturday/Sunday it will be my FIRST trip on my Suki. I have rode there a lot on my atv but never in the Suzuki. I will be the one with Gray Samauri with the Orange front bumper.
Later, [img]images/graemlins/cool.gif[/img]
Old 07-06-2003, 11:42 PM
88.5 Samurai's Avatar
88.5 Samurai is an unknown quantity at this point
Default Re: New to Board have questions?? HELP!!
You can install tcase gears for a little cheaper (and easier). Most guys run the GM alternator with a homemade bracket or one from Trail Tough, Roadless Gear...etc.
WELCOME TO THE BOARD!
Old 07-07-2003, 07:42 AM
Mini4x's Avatar
Mini4x is an unknown quantity at this point
Tcase gears are a great alternative!..
They all lower your high range some and your low range MORE..
Options are
Stock is 1.41 - 2.27
4.16 / 1.58
4.89 / 1.66
5.8 / ?? (anyone know this one?)
6.1 / ?? (this one too?)
Also the Sidekick alternator is a bolt on swap.. and they are 55 or 60 amps IIRC the stock sammy one is 35.
Old 07-07-2003, 11:13 AM
daxe's Avatar
Carpal \'Tunnel
daxe is an unknown quantity at this point
transfer case gears are NOT a cheap way to fix your gearing but they are one of the most cost effective mods in my opinion. You can get a set of 4:16 (GRS1) gears for somewhere around what it would cost you to do R&P front and rear, probably and is overall a smarter choice in my semi-informed opinion.
However, here is a fully informed opinion: a Tracker/Kick alternator is NOT a bolt in swap. My truck runs a newly rebuilt GM alternator (40$) with a Trail Tough bracket (25$) because the Tracker alternator I got to put in it would not allow me to properly align the pulley without grinding the alternator casing in a big way. It can be done, obviously, but it is far from bolt-in.
The GM alt is a tight squeeze but fits well with the bracket from Trail Tough. The pulley only required a little shimming to line up and the wiring is very simple, using a commonly available pigtail from an auto parts shop. My own GM alt is 70 amps but you can get them well past 100 amps if you get the right one. The same style alt was used on just about everything large GM made for about 15 years..station wagons, passenger cars, pickup trucks, etc.
hope this helps and welcome to the board!
~daxe
  #5
Old 07-07-2003, 11:15 AM
Mini4x's Avatar
a Tracker/Kick alternator is NOT a bolt in swap..
Hmm.. I had them both on the bench and they looked exactly the same.. I just left my T/K alt alone when I went 1.6..
  #6
Old 07-07-2003, 08:22 PM
daxe's Avatar
Carpal \'Tunnel
maybe different years have different cases or something, Rob, but there was no way to put the sami pulley on the tracker alt and have it line up. The alt will bolt into the same place and use the same connector, its the pulley thats the issue. There would be no way to get the sami pulley close enough to the front of the tracker alt case to line up. The sami pulley mounting surface is more or less flush with the pulley in the back and the tracker one has a kind of neck on it to reach the mounting surface of the shaft, which is recessed. Its hard to describe. I will see if I can find the parts and take a pic.
~daxe
  #7
Old 07-08-2003, 11:20 PM
TRAILMASTERC
Thanks for the info! How can you tell me what I can ask for at the parts store on the Alt. for a GM ? Make, Model, year? Thanks again for the info.
Later [img]images/graemlins/shocked.gif[/img]
  #8
Old 07-08-2003, 11:28 PM
pugrocker
here you go - link to GM alt. information
HTH
  #9
Old 07-11-2003, 11:43 PM
TRAILMASTERC
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
